peterxj600
  1. The 2.0TFSI engines built about 2008 to 2011 suffer from premature wear leading to increased oil consumption (there is a lot of information on Audi forums about it). Audi in the US have been taken to court over it but no such luck in the UK yet. If you have full service history you may have some entitlement to a repair by Audi, the first thing whey will insist on is an oil consumption test, the exact figures are out there on the net but I think if you use about a litre of oil in about 600 miles you have the fault. I work for a dealer, we had this problem with a trade in, the final repair bill was about £2500 (new pistons, rings and top end rebuild). We don't touch these with a bargepole now. Best of luck with it.
  2. Nice one! Is worth all the effort when you get that MOT cert in your mitts. P
  3. Hi If anyone has a pre-div XJ600 instrument cluster in bits, I need to know the resistance of R12 on the circuit board (the big blue resistor), mine has burnt out and knocked out the revcounter(regulator/rectifier problem). Would appreciate if someone could measure this so I can replace it. Cheers P
  4. It sounds like someone's maybe messing you about. Have ordered a fair few OEM Yamaha bits lately (for a 1989 XJ600, so not a recent model like yours)and haven't waited more than 4 days. I get mine through M and S in Newcastle. Can you try another dealer or is the insurance company insisting where you get the parts? P
  5. Just searched FZ750 and got 121 results. Try leaving out the space between FZ and 750 P
  6. What about a cheap old SR125 to start with? Keeps the insurance low, not too much in the way of bike expense lost if you drop it and you can muck about with it if you want to learn the maintenance stuff. Just my twopence worth P
  7. Christ yeah, what was I thinking, is an RS100 not an inter city 125. Please accept my apologies, been a long week! P
  8. Always best to start with the blindingly obvious (because sometimes I don't and it costs!) but are you using a correctly rated fuse, I believe it should be 25amp. P
  9. Anyone used this on their visor? Can't fit a pinlock to my lid and thought I might give this stuff a go. Am I wasting £15? Fog City Link Cheers P
  10. Any pre-diversion coil will be fine. I know the Haynes Manual shows a difference for 89-90 models but in reality a difference of a quarter of an ohm primary resistance is negligible. My XJ is a 1989, bought my replacement RH coil from Wemoto and it works fine. P
  11. If you get rid of it and need another 125, and I know I may be shot for saying this, you can't get more bullet-proof than a CG125. Ouch! But, if I were you i'd fix it. Any bike described as 'beloved' lol, cannot be parted with. Best of luck with it P
  12. Is fairly well documented that the XJ600/Diversion clutch rattle can be cured by replacing the dowel on the oil pump drive. However, replacing the dowel with a standard Yamaha one does no good because the hole it fits in has worn. Discovered tonight that a gear change roll pin for an Austin Mini (not the BMW one) is a perfect fit, 7/32". They come as an inch long so need to be cut down. Lovely comfortable old dinosaur of a bike but the rattle has really been getting on my tits P
  13. Politics aside, I love the U.S.A. Tried to get a Green Card (work/residency permit) a few years ago but am not talented or wealthy enough to qualify, exactly how I think the immigration system here in the U.K should be. Did meet a girl from Great Falls,Montana whilst I was over there but marrying for a work permit would have been a step too far! Things you should share with us; Dennys, Taco Bell, Gas Station coffee and donuts, Proper sized parking spaces, customer service, tinned jalapenos, cinnamon toothpaste, cheap gas and freedom of speech. You can keep Grits, television and Paris Hilton! Regards Peter
  14. The Motad N-Eta system for the pre-diversion XJ600 looks identical to the original Yamaha 4 into 1 system for the FZ600. Is £300+ from a dealer. I managed to get one (downpipes and silencer) direct from Motad for £79 cos the downpipes are chrome and not black (like that bothers me!). Good Luck P
  15. peterxj600 posted a topic in Yamaha Workshop
    Got the clutch basket off my XJ600(1989) to replace the annoying rattly dowel on the back of it (a factory fitted rattle from what I have read lol). Noticed there seems to be a lot of play with the oil pump shaft and gear, not side to side but I can pull the oil pump gear in and out about a quarter of an inch. Is there supposed to be some play or do I need to order some more expensive Yamaha parts? Cheers P
