Hof
  1. Hof replied to Hof's topic in Classics
    now since Im going to rewire for dirt.. like stated in the above response, again, much appreciated!! when I pop the mag off, theres 3 coils under there, do I really need all 3? arent 2 of the for lighting?
  2. Hof replied to Hof's topic in Classics
    Thank you very much!!! I have yet to do this though, It seems my problem all along was the coil, I ordered a new/old stock one, put it on, kicked the bike over and theres good spark.. so I put her all back together, start her up. she is idling just fine, and then dies... i kick and kick, to no avail,. pop the spark plug out and check for spark.... no spark once again... arghhh....
  3. Hof replied to Hof's topic in Classics
    Also, whats the compression supposed to be on these bikes, ?
  4. Hof replied to Hof's topic in Classics
    Excellent, be nice to be rid of the birds nest of wires.! presently theres no battery, no signals,, and a ton of cut wires and empty connectors.. so other than the wires coming from the magneto, I just need the kill switch wire? . is there a schematic around her anywhere for reference?
  5. Hof replied to Hof's topic in Classics
    Im wanting to rewire the dt175, I have stripped it of signals and lights, now need to eliminate all the extra wires, is there a wiring diagram or a guide for this?
  6. Hof replied to Hof's topic in Classics
    Thanx alot! it was the gasket that was holding it from coming off, problem solved, Thank you!
  7. Hof posted a topic in Classics
    hey all, I just received the piston and rings in the mail, got the gasket set off of ebay.. now Im ready to start the tear it down, and Im now stuck, took the 4 bolts off the get the head off, I was thinking the studs went all the way through to the block, and the cylinder would have came off, but thats not how it is,, the head is off, , the cylinder is still in place, i dont know if its just stuck there and slides off of the cylinder studs, or if i somehow have to take the cylinder studs out to get the cylinder off.. any help would be appreciated... Thanks...
  8. Hof posted a topic in Classics
    Hello there, I need to rebuild the top end of the bike, its a 1976 dt175, I have phoned a few places in town here in Sudbury Ontario, nobody can find me anything aftermarket, I have called yamaha, they are quite pricey!! is there an online resource that you know of. thank you..
  9. Hof replied to Hof's topic in Classics
    ok did a search and found this, but my 1976 is a dt175C
  10. Hof posted a topic in Classics
    is there a site that hosts manuals for old yamahas, I am looking for one for a 76 dt175
