Benj
  1. Thanks Tony, checked out the float height and the jet, no joy. There was a little bit of dirt etc in the carbie, seems all clean now. I pulled off the exhaust as well - no great build ups there. Putting it all back together the bike is running only a little better. It is still bogging down at low to med revs... It will run at very high revs. I was going to run some carbie cleaner through it to see if that helps... Any thoughts on what else it could be if not the jet? Many thanks Scott
  2. Hi there I have a 1983 DT100, and it wont run with the choke off unless it is at very high revs. I was going to check the carbie out. Does anyone have an electonic copy of a manual for the DT100 (1983) that they could point me to? Or can anyone tell me what the float height should be? Many thanks Benj
  3. Hi there I have a simmilar problem with my 1983 dt100. I'll run through the list put together below - many thank! Just wondering if anyone has a current link for the workshop manual??? I cant get the link below to work.... Many thanks Benj
