up.yours
  • Posts
    4,324
  • Days Won
    55
Everything posted by up.yours
  1. thanks lads , thanks for the card jim, do you think i look young for my age then?.. pissy head tonight, twelve hour shift tomorrow,
  2. yeeehaaaa,, welcome teecee, it's a great site,, iff you blend with knob heads . and ill be your best friend for a pint... , but don't feed me im on a diet. .
  3. oh, a new caracter for the squires bash 2011, welcome to the madhouse, i may let you buy me a pint, but then again your only 16 so you can give me the money instead .
  4. is this what you call spam..
  5. consumables available here http://motorcyclepro..._4915_4916.html rear lens available here, http://www.wemoto.co...V_50_M_P/74-82/ this is no good to you im just showing you that parts occasionaly turn up http://cgi.ebay.co.u...l-/270676852280 im doin a small 50 up at the moment , hope you have fun with yours. and you'l be a bit miffed at missing this, http://cgi.ebay.co.u...em=170602842329 anyway i hope this gets you started , good luck mate.
  6. sounds like your coil could be breaking down under load. ride you scooter at 30 mph for a while,, iff it rides without dying this could confirme the coil theory.
  7. thanks pat , i just put an order in for one off ebay £11.40p.the same one as you put up.
  8. erm,,,, what will i use to charge it,,
  9. ta andy, i put another one up ,it's on flea bay ,take a look see what you think.
  10. will this be ok to charge my bike battery http://www.google.co...0CAwQ8wIwATgA#p or will i need one of these. http://www.google.co...0CAcQ8wIwADgA#p oh , i just found this http://cgi.ebay.co.uk/BATTERY-CHARGER-6-VOLT-12-VOLT-MOTORCYCLE-SCOOTER-/280513201948?pt=UK_Motorcycle_Parts&hash=item414fe3c71c so which one should i get
  11. the parking light is normaly a seperate pilot bulb, which is why your parking light works. it could be ,just a loose connector on the back of the headlamp. whip the light off and take a butchers to confirm.... may be change the big bulb.
  12. up.yours
    ELECTRICS.
    stop messing about you two,, this is serious shit you know,,,
  13. feck me drewps,, i must o blinked and mist ya mate,,, well done.
  14. http://www.youtube.com/watch?v=ShacMAn_HK8
  15. home bargains do sone different coulored torches for 99p with batteries,a bargain , and their bright, all you need now is gaffer tape
  16. up.yours
    ELECTRICS.
    1 the indicators all light up, i will check the wattage tomoz. 2 spot on with this jason the brake light is fine when nothing else is being used.also noticed today it worked ok for a short time then played up again ,this leads me to suspect no charge in battery. 3 horn works fine as above,with nothing else switched on . i will have to scounge blag or steal buy a 6 volt charge tomoz. cheers jason.
  17. what amazed me .was he never fell off his bike.
  18. up.yours
    ELECTRICS.
    N0 1, the indicators flash very fast. N0 2, the lights all work when switched on ,but when i brake the brake light dims instead of brightening. N0 3, horn works intermittent.. it's a 6 volt system and i don't posses a 6 volt charger. would i be right in assuming this is what i need. it's a new (so im told) battery .new relay and im getting a feed to the battery through the jenny... i like most on here am shit on electrics. so can anyone advise. thanks in advance PASSOLA MAN..
  19. just like two dogs with two woziitz,arn't you. (drewps n ogb ) welcome to the madhouse sandra . i hope you find all you need on here.
  20. up.yours
    Module 2 test
    bad luck mate , but don't let this faze you, the worst is over ,you know what a fail feels like. hopfully you will know what a pass feels like next time,, good luck for the future.
