roodie
  1. I rigged a clear hose from the pump outlet hose back to the tank. I'm just letting it recirculate for now. I haven't completely given up on the pump.
  2. Found the ball and spring, I did stretch the spring a little and replaced it all. Still the same. Going to bypass the pump and mix the fuel.
  3. Thanks for the info....will look into the spring check first !
  4. I recently bought a 75 250 enduro in non running condition. I have gotten it running, but in 15 minutes it drained the oil tank. It was blowing oil strait out the exhaust pipe . Is there an adjustment on the pump or do i have another problem ?
