the doc
Everything posted by the doc
  1. the doc replied to the doc's topic in Classics
    I didn't know that no more lrp. The plan now is i'll check fuel filters clean or change if pos check fueltap for any obvious damage run again finally strip and clean the carbs manually ha ha ha i've been dead reluctant to do this as i've seen people do this and the bike never ran right again, (i assume when you say clean remove any obvious blockages) the comment about the coil sounds reasonable because with it conking out its like something is breaking down over a period of time in fact i might try that second before the carb strip cheers
  2. the doc replied to the doc's topic in Classics
  3. the doc posted a topic in Classics
    I've just bought an xs 250 although it starts ok it won't go above 40 mph and conks out after a mile or two it restarts again after about 5 minutes to repeat the same thing all over again i've used a lead replacement additive and also redex in an attempt to clean the carbs has anyone any idea's what could be the problem?
