eagle56
Everything posted by eagle56
  1. eagle56 posted a topic in Naked
    Any suggestions on a good all weather tyre choice for commuting and scratching for my thundercat
  2. Good luck, hope the bastards are strung up. Keep looking on E bay
  3. Heli bars look good but bloody expensive and other options
  4. eagle56 posted a topic in General
    will r6 risers fit a cat
  5. eagle56 replied to eagle56's topic in General
    sprayed mine with wd40
  6. eagle56 replied to eagle56's topic in General
    water and soap sounds good, iv read that you should clean with solvant (not sure if i like this )and oil it afterwards. do you oil it or put it in dry
  7. eagle56 posted a topic in General
    are these foam filters washable
  8. Want to take off the carbs and give them a clean out is the easy what should I beware of
  9. eagle56 replied to eagle56's topic in General
    Mine runs rough at low revs but fine at motarway speed and wide open I surpose this is not down to cab icing otherwise it would be the same at all revs. strange it happens only when its warmed up?????????
  10. applogies I was not aware of the rules.
  11. eagle56 posted a topic in General
    what is this and how does it effect the engine
  12. Non in there and for some reason I can not put a wanted advert in there
  13. My cars sit outside of the house ,all year round I ride to work and back come rain or shine I hate driving the car and getting stuck in traffic i'll take two wheels any day
  14. Removed as per forum rules Goff
  15. Sorry if you have read this in workshops. My cat was fine with the exception of the choke not functioning. I left it a couple of days and I had trouble starting it I opened the choke and the choke seemed to work for a while great I thought, but ever since it misses in low revs, motorway and excelleration is fine. If I am riding under 40 it hessitates. any ideas
  16. its more like when it warms up rather than hot hot
  17. if so are they renewable
  18. My cat is fine at motorway/cruising speed and high revs but when hot going slow on low throatle it runs jerky like its miss firing any ideas.
  19. Thats good to know. great engine leans a bit to forward for me, Im trying to get used to it, big difference to my Fatboy and K75rt.
  20. tick over is a a bit slow the bike returns 60 mpg if not thrashed so there can not be much wrong. one other thing is there is a lot of slack take up through the gears any suggestions thanks steve
  21. just bought a cat with 45k the gears have a whine in 3rd is this norm and for some reason the choke is not working properly, I can put it full on and the engine cuts out part on and it does nothing. Its anoying that I have to rev it till it can tick over on its own is there an obvious reason for this.
  22. eagle56 replied to Joshua2's topic in General
    Only from second onwards
  23. Ive just bought a thundercat and being and old bastered I am having difficulty seeing the small numbers on the speedo. is there such a thing as a film that goes on the speedo lense to magnify them.
  24. eagle56 posted a topic in Naked
    Would like to know if anyone has fitted ba risers to their cat and do they make any real worthwhile difference. I been looking on E bay for ages and they dont seem to come up, is this an indication that no one uses them. They only lift the bars 18mm which is a very small amount
  25. Just bought a cat and cant get used to it I think I need risers, where the heck can I get them from and are they any good. I need to sit up more.
