XS400 Charging System and Electrical Questions
I detached everything and polished with steel wool. Took it all off, battery box included and cleaned everything. Now, the regulator test, the battery is reading 13.8 at idle and 14.2 V under 4000rpm. And, the voltage isnt going any higher. The clicking is mostly gone except for a slight one by the left hand side panel when the ignition key is turned. I put inline blades instead of the original fuse box, bit of a clunky fit, thanks to my wiring expertise not being so great. Removed the headlight and looked at the wires and connections but didnt find anything exposed or blackened even. Im going drive around and use the left turn signal repeatedly to see if anything happens again.
Hi there, My bikes a 1977 Yamaha XS 400 2E - 2G5 series frame number. trying to do two things, 1 ) fix an electrical / charging problem 2 ) understand the electrics better I was out for a ride the other day, bout 60 miles / 2 hours, temperature low 80's, left turn signal pilot went solid after about an hour and a half, small while later the signal fuse melted ( pilots went out ), after about 30 mins, bike running badly - stutters, backfires, power decrease on hills - then stalls. Starts but only goes for about a mile. Checked the battery voltage, 12.4V under 0 RPM and 5000rpm. I have had the headlight off recently when putting on on a new tachometer. What my Bike Looks like. Alternator - There's two branches coming out of the alternator, one ending in a female connector containing three white wires and one yellowishy white wire and one ending in a male connector with a black, green, yellow and light blue wire. Rectifier - On the bottom of the battery. Black grid shaped thing, white wires going in, black wire and red wire coming out. well they look like they are all just going in...or coming out. Regulator - Its that black rectangular thing at the back of the battery and underneath the fusebox. That looks old. like something off a really old telephone. Initially I did have it confised with the turn relay, a cylinder shaped silver item with a three prong connector from nippondenso which has, ND FN 257E / 12.8 V 85cm / 27W x 2 + 3.4W / NIPPONDENSO / 061300 3572 printed on the side. Heres what it looks like on paper. XS 400 2E Wiring Diagram So, Im checking the alternator by the haynes manual method and trying to understand the wiring diagrams, found some colorful ones referenced in other threads. Alternator Test : ( Using actron CP7665 Multimeter from autozone for all tests ) Checking resistance of each of the three white against the yellow. Checking the resistance across the green and black wires. Resistance Readings ( at 80 F - multimeter set at 200Ohms scale ) : White wires : .7, .6 , .5, Green and Black : 4.3. White wires - field coil - ( coming out of alternator ending in a female connector ) - three carrying current from the windings go to rectifier, the last one goes to the turn relay - is this to eventually connect to the ground the turn relay is connected to ? multi colored wires - rotor - ( coming out of alternator ending in a male connector ) - yellow, light blue, going to pilot box. green going to regulator, black going to left handlebar switches, why is that going there ? Green going to regulator, Is this the actual voltage being generated input for the regulator. Also, Is a current from the baterry passed through a winding on the rotar to begin with to induce a field which afterwards is fed by the alternator itself. Or are there permanent magnets. Rectifier Test. : checking resistance of the red wire and the black wire across the three white wires. I get no readings going one way and when I reverse the probes while I do get a brief resistance reading, it flashes up on the meter, then returns to the default value of 1 ( which is the value when theres nothing connected to the probes ) I did the test with the diode check function of the meter, I got constant readings of 625 one way and the other way it just stayed at the default reading of one ( when theres nothing connected to the probes ). Is this rectifier ok ? whats with the resistance reading not being constant ? Regulator Test : I need to charge the battery up now and do the haynes test for the regulator. Also, theres a clicking noise when I turn the key in the ignition coming from the battery section, is this indicative of a grounding problem, if so, how do you test the grounds ? With Thanks. Adventures in Electrical Systems...Bzzzzzt Ouuuchh !
oops, this got double posted
Drum Brake Actuating Lever Rod Securing Bolt -- Doh
Thanks Tony, appreciate it. Ordered off the internet and part arrived yesterday and fits into place perfectly. Cost $1.40 .It was described as a 'Pin, Special Shape'. And the part was listed in the 'Stand - Footrest - Brake Pedal' Schematic, # 42, in the 'Control and Brake' Category, I had been looking at and listed earlier in the post was in the 'Wheels - Tires - Final Drive' category as the 'Rear Wheel' Diagram. http://www.bikebandit.com/houseofmotorcycles/yamaha-motorcycle-xs400-2e-1978/o/m8253#sch214797 Thanks Again, Gazampa
Thanks for the part number, thats what I really need, hopefully can reorder it.
Sea, Tuiguim. Is iomi shli much a mharu, seachas a machadh le t-im ach B'fhearr liom an phairt o OEM. Beadh sin a bfhad nios fearr.
Could be, im using bolt as a generic term, dont really know what its proper name is.
Hi There, I had a back wheel off for maintenance and when putting it back on found im missing the bolt that the brake rod goes through securing it to the actuating lever. I uploaded a picture, its not numbered but its that cylindrical bolt with the hole in it between the digits 27 & 28. Any Ideas on where to get a proper replacement, I figure on going to a hardware store and browsing for something that will fit. The Bikes a 1978 Yam XS400. With Thanks,
Resurrecting a 78 xs 400 thats been sitting for five years
Ive been riding each weekend now since the one before labor day and using it during the week for short trips. It could still do with a bit of polishing but for now its running well. I've put about 800 miles on it and that includes one ride of a little over six hours last weekend on a medium hot day of about 70-80F which it handled well with no complaints. Its got something to say pretty much throughout the rpm range and pulls well from mid to high. The acceleration is not comparable to anything modern I imagine which is great from a safety point of view. I understand leaning out the mix can give it a bit more burst but at the cost of higher engine temperatures. Its hard to beat the sound that it makes, its very throaty. The gear box is a little tight sometimes going from second to third, could just be this bikes gear box, and it slips out of fifth into neutral sometimes which is not cool. My tachomoter is not smooth when its warmed up, it bounces around, it can jiggle around a range of about +-250 rpm. carbs probably need better balancing im guessing. The right side was always complaining, i found that the exhaust engine port was loose on that side ( it fell out, whoops ), but after getting it back in, there was a great improvement vis a vis starting. The o-rings on the idle screws helped big time. It was starting to get there and the o-rings pretty much got it there. On early rides, the sparks carboned up a bit and made starting very hard but after a little sanding and just riding the rpm a little higher, they cleaned up and are tanned. From a starting point of view, its starting really well without any problem at all. The temperatures have been a little chilly lately but it hasnt been having a problem. The current list of fix mes runs as follows. 1 ) Forks weeping on left side. 2 ) new brake pads. 3 ) new Front Tire. 4 ) vacuum balance carbs. Idle still needs a little nursing. Outside of that, a deep off frame clean and a frame repaint would go most of the rest of the way to a full restore. If I find a place for winter where I can work I might give it a try, falling short of that I'll just store it. The pipes are pitted from standing and should be replaced going the full restore route but they are not bad for general use and in good working condition. I might just take care of the fix mes and then maybe sell it on later, hopefully to someone who will take it the full way. As of now though I would call this xs400 resurrected. I wouldnt call it fully restored but its certainly up and about. Heres a quick vid, ill maybe post a better one in a bit, just noticed the kick was a bunny ho, not really for public consumption but there it is. Video
How Strange The Change From Brass Floats to Plastic
just to drop back and finish off this thread. I had a problem with the drop level using the plastic floats. The drop tang that hits off the post was too small. They could be rigged but ultimately, I bought a couple of stock brass floats from the dealer at an extra 20 bucks a pop. Small price to pay for peace of mind whilst driving around to not be thinking that a rigged tang on the float was going to somehow come asunder inside the carb. The high rpm was down to the throttle screw position.
put 50 miles on it over the weekend. Took it out for two runs of about 25 miles each. I may have missed the airshow ( through my own inexperience, not the bikes fault ) but I can still give it a ride downtown along michigan avenue amidst the skyscrapers and all that, along lower wacker to get the full amphitheater effect of the pipes and up along the north shore for a hint of the cafe racer feeling. Vrooom, Vrooom. The idles not perfect but it is a work in progress, its a little on the high side about 1400, Im new to this but i think im getting the hang of tuning it in and am working on getting it down to 1200.
1978 XS400, Trying to get her running again.
been working on a similiar project over the summer and have just got a 78 xs400 in running around condition. Its been sitting for five years, theres a thread about it on the forum. Cost wise : new battery - 44.95 ( local dealer ) carb cleaner - 4.95 ( local dealer ) Depening on the condition of your carbs. new floats - 42.95 each ( local dealer ) carb kits - 35 each ( www.siriussonic.com ) Theres also brake pads and tires to consider, havent had to get into those yet. Bought a couple of new tools but didnt need much outside of a standard ratchet set, did buy a multimeter for $20 at autozone, would like to buy more stuff but so far havent gotten to it. The carbs soaked up virtually all of my time. Its my first time, someone more experienced would probably have done it over a saturday afternoon. Get stock parts as much as possible, dont try and pinch pennies on cheaper alternatives. This can suck up time. Overall, its worth it, Im having a good time with it now and still learning. I found the work enjoyable and though frustrating at times, its definitely satisfying to get it out on the road.
Oh, you mean the big screw, the really big one...the biggest one on the whole carb. Christ, I am such an amateur...Yeah, gave that a couple of turns and down came the RPM. What can I say, I like to think it was the fumes. Man, did that feel good though. Still have to tune it in properly but just to not have a screaming idle is really really satisfying right now. Jesus, it feels good. Thank You for that. I wish i could buy you a beer. And that goes to everyone who has helped so far. How does that screw work though, I saw that it pushes open the throttle valves, does that create greater vacuum to suck up more fuel from the bowl. And how come opening up the valves via the throttle on the handlebars increases the rpm. Whats goin on there, I can read up on the internet I suppose. Thanks, will do.
Am completely stuck. I cant get the engine to idle. Is there a secret handshake involved, then again this is my first time tuning carbs, I say that to myself to stay calm but I am going #$%# banannas throwing myself against this. Utter frustration. 1 ) 2 New carb kits from sirius. Able to spray air through the passageways. Two new Idle screws. 2 ) 2 New floats ( genuine yamaha brass float for this model ). Fuel Level set about 5 mm below the lip, thats as good as I could do, I could get higher by taking out the washer in the fuel valve assembly. 3 ) 2 new air filters. Genuine yamaha parts for this model. 4 ) Sprayed WD40 around the boots and no change in anything, sprayed it around carb and no change in anything ( the engine was on ) 5) Before I set the fuel level in the bowls, I was getting backfires on deceleration and shutoff. Now, thats cleared up. Started with the idle screws fully screwed in and backed them off, I did start to get backfires in the left exhaust. But with the screws full out there was an idle of 5k, i think that was just the engine getting fully warmed up though and the idle rising with it. Any ideas, Are these carbs just garbage ? Are there specific settings for the pilot air and fuel jets ? Mine are in all way, thats the way they were when I got them, should they be turned out a little or seated firmly. Is the choke circuit toast ? When I pull the choke out, rpm increases. I figured that was normal for a choke, I dont understand why enriching the mixture didnt slow it down. Is the hgh rpm due to a too rich mixture. Ive been assuming its lean as evidenced by the lean backfiring earlier. Do the idle screws need o-rings, mine dont have any ? Im very grateful for any contributions.
Project is moving along, after replacing punctured floats im working on high idle with a warm engine, i understand its a lean mixture problem most likely caused by too low a fuel level in the bowl, its about 8mm under the lip. Im going to reset float heights and am using a fuel level gauge. So far adjusting the idle screws is not affecting it. I posted a seperate thread about the float work. First of all the floats were stuck, then punctured, now too low. Grrrr, floats. And the new floats fall so low in the bowl allowing the needle to fall out low enough to jam them. The tang on the back that hits off the post is not big enough. I am walking in the shoes of Torakusu Yamaha as he endeavored to tune his first reed organ. The air show came to town, I pedal powered over on my bicycle. Ive got enough progress to be reasonably content with but its not air show quality just yet. The idle is very high and in a crowded area with a fairly rusty driver, it would not be very cool. Getting the carbs right is taking me some time, a rebuild from the sirius kit with new floats was in order from the outset. Here a couple of photos from the papers, i dont think any of these guys would drive a bike with high idle and who knows what else just yet. ( At least thats one thing i might have in common with them ) I have used it to jet down to the store though and the circumference around my appartment which I am driving is increasing. Im not flooding the engine anymore but its very dry. photo1 photo 2
gazampa
Joined
Last visited
