daisybrown780
  1. Hi, thanks for getting back. Fuel getting to both float chambers, all jets are clear, feed pipe from tank free flowing, when i start her it will not pull the fuel through the carb, i can manually lift the main needle slide in an attempt to draw more fuel but no affect, i have checked the diaphragm and it is in good order, i have pulled a small vacum on the diaphragm and it functions correctly, it operates the needle up and down. Yes i agree it has to be a blockage somewhere or possibly sucking air but i have checked everything and can not find the problem. The bike has been parked up in my garage for 10 years and it was running perfect when i put it there.
  2. Hi Can any one advise on why my 650 xs special L/H carb will not deliver any fuel to the cylinder. Got good spark, good compression, just can get fuel there. Stripped carb and can not see anything wrong. thanks
  3. Yes fuel getting to both carbs, bowl vent is clear and i have equal compression on both cylinders about 125psi
  4. daisybrown780 posted a topic in The Bar
    Hi Can any one advise on why my 650 xs special L/H carb will not deliver any fuel to the cylinder. Got good spark, good compression, just can get fuel there. Stripped carb and can not see anything wrong thanks
