keno
Everything posted by keno
  1. keno replied to keno's topic in Yamaha Workshop
    Just changed the carrier bearing and still the same,was looking at the rear wheel while in gear and on centre stand and it is juddering and noisey,i checked the wheel bearings by spinning on the spindle while out of the bike and was smooth with no noise,tryed different settings for wheel alignement but still the same,only seems to do when in gear,also rechecked front sprocket for play and it is solid no movement,doing my head in,HELP! Heres a quick vid of problem looks worse in real life than on vid rear wheel also judders and stops and starts hard to see on the vid.
  2. keno replied to keno's topic in Yamaha Workshop
    Yep 15-48 tooth,soft link on chain pressed 20mm width same as rest of links,rivets nice no cracks, chain smooth when wheel pushed by hand soon as its in gear chain starts jumping looks like it wants to jump of front sprocket and noise from front sprocket or clutch side,not sure if noise is just vibrating through to the clutch side.
  3. keno replied to keno's topic in Yamaha Workshop
    Will do,as soon as i have finished plastering kitchen . Cheers.
  4. keno replied to keno's topic in Yamaha Workshop
    Bike was running on original chain and sprockets,sprockets showed no sign of wear chain had a few tight spots so renewed as a set,there is no spacer for this bike,might try changing rear sprocket carrier bearing see what happens,when i had the carrier off last week i span it on my finger and the inner race of the bearing was moving slightly in the direction the carrier was moving,dont think that is normal but not sure?
  5. keno replied to keno's topic in Yamaha Workshop
    bought as a kit "DID 530 X RING" checked sprocket shaft left-right & up-down with no play,thought it might have been the shaft bearing still hope its not any ideas cos i,am stumped.
  6. keno replied to keno's topic in Yamaha Workshop
    yep all straight and spacers on right sides,this problem is doing my head in.
  7. keno posted a topic in Yamaha Workshop
    Got a 98 fazer acting up,problem is when riding slowly behind town traffic or even pulling away there is a lot of noise from front sprocket cover or the clutch cover (hard to tell)and the chain sounds like it is trying to jump off the front sprocket,also if the bike is on the centrestand the chain jumps up and down and sound like it is jumping on the front sprocket making a terrible noise,i have changed the chain and sprockets and replaced the nut and washer but still the same,chain is also tensioned proper 30-40 slack,bike rides fine changes gears fine just slow riding 10-15mph and pulling away causes this, bike has only done 10700 miles, could a stiff rear sprocket carrier bearing cause this,i checked the bearing by spinning the carrier on my finger as hard as i could and it only managed about 4-5 full revolutions there was no grinding noise just seems a bit stiff, a friend had a spare carrier so brought it around and his spins forever but has a slight noise coming from it. All help appreciated.
