08wrick
  1. Hello mate its me again. When i said the screw in the middle of the black plastic thing i didnt mean the 1 that holds it on i ment the one slightly off centre.... cheers give us a ring if stuck on 07770570118.
  2. Hello mate! just to saythe best 2-stroke oil to use is Castrol TT in a black bottle! Silkoline is crap really.. MOtorex is the best but its to thick to run through the oil pump... I've herd so mch about this wire and earthing it off to the frame! but which 1 is it??? That little seethrough ovel thing behind the speedo duz nothink when taken out or cut lol. bt i would'nt mind finding this wire u earth off? My 2001 DT125R duz 95 and 105 down hill.. easy, All i've done is on my power valve cables no1 is all the way down and no2 is fully out and I have a full Dep. When you sat it aint reving over 7000 is yrz electric power valve? if so on the left hand side of the barrow is the power valve take the little cover off and you will see a black plastic thing with two cables coming down either side and in the middle will be a screw which is put there when new to restrict it! when you've taken it off start the bike and rev it and you will see it move slightly then take the screw out thats in the middle and rev it again and it should move alot more and yr bike will rev off the clock!!! wb soon....
  3. yeah it is possible to get 90+. You need a Full dep pipe and to ajust the power valve cables! Don't bother with these exausts: Big One and Arrow.. I have a 2001 DTR125 and it tops out at 100mph and all I done was full dep and set up the power valve cable no: 1&2.. 16t sprocket on the front and 52 on rear. I also hear about this ovel speedo restrictor behind the speedo and a wire that goes into the speedo sumink about chopping it and earthing it off to the frame?? I duno i dnt wana really do it if it does'nt work! My mate has a 2001 DT125 RE and I've done the same as mine and his is very fast. He does'nt have a rev limiter and it just pulls and pulls alot faster than mine!! Only thing is is that I have a Y1 head and Y2 bottom where he has a Y2 head and a Y1 bottom. Not sure if thats wat it is???? What DT have you got? where u frm???? wb soon!!!!
  4. No a standard silencer isn't better! I have a full dep and its alot better it revs out to 12rpm.. Don't bother buying a big one exaust because they crack off at the flange and they don't really make a differance it just sounds nice!!!
  5. I totally agree mate.. if you want a few tips? i can help you!!!
  6. Well mate I have bad news for you! my DT tops out at 105mph. all it has is a full dep and ajusted power valve cables. 16t sprocket on front and 52 on back lol
