mrbmike
  1. I just picked up your look alike last week. I just did a full service on my bike. With regards to to engine- after you change the oil- there is a screw on the right ride beside #4 spark cable, after you change the oil- you have to loosen this screw to see if you getting oil to the heads, if you see oil seeping around the screw your good,tighten it back up. Your clutch needs adjusting, you may just have a worn or damaged spring in the clutch case, easy fix. Just a question for you was wondering what your rpms are at idle and driving at 80 KM in 6 th gears. Mine idles at 500 but it should be around 1100, The battery only charges at 1000 rpm.
