Everything posted by glen webster
- Glen Webster
- Glen Webster
		Micheal Jackson
		we all pass on at some point and i am not saying he did or did not do all that stuff but i never did like him or his music so no big loss
		Other forms of transport
- My '78 XS 400E.
		vstar 1100 (european) vin code?
		the Vin # can be found on the frame between the forks it is a 17 digit # hope this helps http://www.motoverse.com/tools/vin/yamaha.asp this is what it told me about my bike World region:Asia Manufactured in:Japan Year:1996 Make:Yamaha Model:XV535/S Body style:Road / Street Drive type:RWD Cylinders:2 Cylinders
		roadliner vs midnight star
		just maybe the name thing so any one that want to compare Yamaha V-STAR bikes to the roadliner can go here http://www.starmotorcycles.com/star/produc.../0/compare.aspx
		who are we all
		OK ill tell y'all about me my name is glen i am 40 and live in southern IL. (USA) after high school i got in to maritime fire fighting done that for 10 years after i left that i got into residential fire fighting EMS and hazmat op's been doing that for the last 12 years at this time a ride a 1996 xv 535
- Look what i got!
		that would be 102 CI (1670) some times thy round up and call it 1700
		carb balancing/synchronizing on an '82 xj 550
		don't know what a Harley shop charges but i do know Yamaha of southern IL charges $69 and hour i would guess it about the same at most shops
		as stated i got my specs from Yamaha http://www.starmotorcycles.com/star/produc...484/0/home.aspx the only 113 ci are the 2 Roadliner Stratoliner and the Raider
		xv535 with 750 wheel??
		here is the tire specs for both the use the same tires 140/90-15M/C 70H, xv 750 140/90-15 70S xv 535 so the rear wheel should fit
		Question about mileage and other mechanical stuff
		that would be my guess take it in and have them cleaned and balanced
		Word Association Thread
		pay back
		here is a side by side us specs from Yamaha Motor Home Roadliner / midnight star Bore x Stroke 100mm x 118mm/ 97 x 113mm Carburetion Twin-Bore electronic fuel injection;throttle position sensor/ 40mm Mikuni CV w/throttle position Compression Ratio 9.48:1 / 8.3:1 Final Drive Belt Belt Ignition TCI: Transistor Controlled Ignition / Digital TCI Transmission 5-speed; multiplate wet clutch/ Wide-ratio 5-speed Type 113-cubic-inch air-cooled 48° V-twin / 102 cubic-inch air-cooled, pushrod OHV, 48-degree V-twin you can check out specs at http://www.starmotorcycles.com/star/overview_byo.aspx
		Sitting too close to the exhaust - suggestions?
		your welcome
		thy can be a pain to install you have to remove the OEM pegs then remove the pegs from the brackets then install the boards to the OEM brackets then reinstall them on the bike so the brake will not be in the wrong position
		Why are Yamaha bikes so cheap?
		don't know why thy are cheaper but that should not worry you Yamaha is one of if not the bike on the market
		wot is the best yamaha of all time
		Ive had a few but i think i like the xv 535 s the best
		the Way i solved that was to put boards on it 148,36 $USD thy can be got at http://www.bikercom.com/shop/index.php?pag...mp;ref=H732-060
		Had charger on battery, gas tank touched it, sparks flew, now weak battery...
		does the bike have a main power fuse if it does you could check that if that ain't it try a new battery and hope you don't need a voltage regulator
		Help XS1100
		well it could be as simple as the carbs need to be cleaned and or rebuilt or could have restricted air flow that would be what i would check first
		Will they fit
		your welcome thy are nice pipes i think you will like them
		1973-74 tx 750
		cant say i know any thing about the tx 750 till 2 years ago i was still riding my 79 xs 1100 witch was my first bike that i got in 1987 or 1988
_33963e.png)
    _83bc35.png)
