phil63146
Everything posted by phil63146
  1. I think I may have found it. It struck me that when I removed the plugs to check the compression they were finger tight. After putting them back in and making sure they were tight I took the bike around the block a few times. There seems to be a definite difference! Normally, I would have pulled the carbs and done probably 10 more hours worth of other work, put it all back together, have it run great, and not have the slightest idea what I did that might have been the fix. Looks like I may have lucked out. Thanks.
  2. Still haven't gotten to it yet.
  3. If it's there I would bet a week's pay that I did. Idea! I will take the air box off the bike, start it, speed it up, and see if the piston valves lift. If so that would indicate to me that the bike should be getting (hopefully enough) fuel through the Main jet. I will try to see if both lift at the same rate. May be a day or two on results. thanks
  4. Yes I removed all that could be removed from the body (main jet, pilot air jet, main nozzle, etc) , but I did not disassemble the jet needle from the piston assembly, separate the carbs, or remove the starter plunger (choke).
  5. I have inspected the diaphragms under a magnifying lens and held them up to light and see nothing out of the ordinary. They are very supple. I'll pull them again and reinspect. Yes, I have cleaned all the passages in the cards and run fine piano wire thru the openings. I compared passages/openings between the both carbs and everything between then is the same, blew all the passages out with compressed air. Phil
  6. 1982 XS400RJ, 30,000 miles with absolutely no horsepower. In the 1,000 miles I have owned it top speed was 45 MPH which was OK cause I didn't need to go any faster. Now I do. I had the engine out earlier this summer and here is what all I have done to/around it, with added info. After all that work the bike seems to have no more power than before. Compression is 135 and 140 PSI, new plugs, adjusted valves (way off), new fuel filter and lines (see thru), premium gas, cleaned carb and passages, spotless internals, diaphragms look great, changed both needle and seat assemblies (both old and new same float height setting), adjusted air screws and synched carbs, no popping or backfiring, smooth idle, bike starts instantly, clean air filter, gas tank is clean with no trace of dirt in fuel lines, clutch adjusted properly, different ignition box. Throttle response is great, it's just that I'm in 5th gear by 20MPH. I have not checked the timing yet, what is the best way?. Exhaust seems to have sufficient output but maybe I need to disconnect them. Anyone have a way to check mufflers without disconnecting them? Is there a sane way of checking float level? Unable to talk to prior owner. I can hold the brake and when I engage clutch the engine dies. It will also hold me on downhill slope with engine off and clutch engaged. Any ideas greatly appreciated! Thanks in advance. Phil
  7. Found them from another owner. Thanks
  8. I have a question you might be able to answer. On the pilot screw is there just one O-ring and washer per screw or two washers with a O-ring in between? If just one, I assume the washer goes against the spring (dumb ? I know). Thanks for the lead but I'm hoping to find someone on the west side of the pond.
  9. Where can I find the flat washers and O-rings that fit on the pilot screw (air mixture screw) on the Mikuni carburetor. All of the items are about 5mm on diameter. Thanks in advance. Phil
  10. Thanks for the info! I'll be ordering those along with carb kits. I'll be sure and post the results. Phil
  11. No, it is definitely gas and not oil. Looking at my factory book I can't identify what cap need to be pulled to be able to adjust the air/fuel mixture. What is the air/fuel adjuster called in the parts manual? Thanks, Drewpy. Phil
  12. 1982 XS400 bike. This bike will make your eyes water after 15 seconds, it runs so rich. The air filter is clean and both plugs are firing. The factory book shows no air/fuel mixture screws on the carbs. Earlier years show having the air/fuel mixture screws. Does anyone have experience in correcting this problem on this vintage bike? Thanks in advance. Phil
  13. Here's what you do. Get a 6 or 12 point 12MM deep socket. Put it over the lock nut, hold the socket with a vise-grip. Insert a Phillips head screwdriver (through the 3/8 or 1/2" opening where the ratchet attaches) and holding the screw stationary, turn the socket counter clockwise to loosen the lock nut. Make necessary adjustments. To tighten the screw after adjustment, hold the screwdriver steady and turn the socket clockwise to tighten the nut. HINT: replace the clutch cable (I wasted a lot of time on a seemingly good but stretched cable). I will forward from the factory book the clutch adjustment procedures (in correct sequence) if desired. Let me know. Good luck. Phil
  14. phil63146 replied to phil63146's topic in Naked
    Good thing I bought the extra ignitor because the rebuild project has so far been a failure. I don't know if I will ever attempt to find out where things went wrong.
  15. This bike runs so rich it makes your eyes water within 15 seconds. The air filter is new. Both plugs are firing. The factory book shows no adjustment for air/fuel mixture. Surely syncing the carbs wouldn't fix the problem, would it? Any ideas before I tear into the carb to check float, etc.? Thanks in advance. Phil
  16. phil63146 replied to phil63146's topic in Naked
    Nothing to report on the ignitor rebuild. When I am finished with the ground up on the bike (except engine & tranny) I'll concentrate on the ignitor. I also purchased a used ignitor (at a fair price) as they are getting scarcer every year.
  17. phil63146 replied to phil63146's topic in Naked
    The I.C. was made only by Hitachi and I was unable to find any spec sheet on it. The power transistors weren't too much problem to match and more than likely are the culprits. However, I don't trust the electrolytics so they will be replaced with 105 degree C ones. I plan on using 1% resistors as several originals have drifted. Concerning the small (unmarked) signal diodes, I think I will re-use the originals (what do you think)?
  18. phil63146 replied to phil63146's topic in Naked
    I have successfully opened the module and found and received the obsolete power transistors and integrated circuit from a parts house in China. There is a small printed circuit board of which I can't identify the surface mounted components, but they are used to process the signal from the sensors so it should be OK. The 2 power transistors (one for each coil) and if it should die, there goes the fire from one coil, which makes a restart almost impossible. Those transistors take a heavy load and do a lot of work. I believe the integrated circuit is OK, but since I have a replacement I will replace it. The balance of the components on the main board are of the common variety and should be locally obtained with no problem. The big hold up is my having stripped my bike down to it's bare frame for a thorough cleaning, painting, and reassembly. If I didn't have confidence in the ignitor rebuild I wouldn't have the bike in pieces. I'll let you know how it goes.
  19. I was having the same problem. hard to start, Darn near impossible to restart, acted like a loose carb the way the engine surged at idle. Then it totally died. Removed the ignitor and it's cover and noticed the circuit board had a lot of cold solder joints. I took a small wattage soldering iron to it and resoldered all of the connections. It fired right up and ran great, for 975 miles, then it started the same scenario. Resoldered the joints again, but to no avail this time. You have to be good at soldering or you will have a mess on your hands. I am currently trying to find some old ignitors to take apart and experiment replacing key components. If you want to send me your ignitor (12R) I will be happy to resolder it for you and send it back (my reward will be trying it on my bike to see if mine is actually bad). If interrested, please contact me. Phil
  20. phil63146 posted a topic in Naked
    I am looking for dead 12R ignitor modules for an 82 XS400RJ or similar to experiment taking apart and replacing key components. If you have an old one you would like to donate to the cause, please reply.
  21. I would suspect bad solder joints in the ignitor module. I took the cover off and resoldered all the joints (but one) and had about 600 trouble free miles. It crapped out (while hot) on me yesterday, and I found one lone cold solder joint. so I soldered that. Hopefully that will do the trick. The solder joints on the circuit board start cracking after the years of use and getting the heck knocked out of them. I sure hope that solves my problem, and yours, too.
  22. Is there an aftermarket tach kit any of you would recommend? (original has bad clock spring). Thanks
