Just logging in to respond
  1. Is anyone still looking at this thread?
  2. The DT200 was mine and had the same symptoms described. I made up deveral keys from scrap but they kept shearing off so I got one through Yamaha - fixed. Also the DT175 would actually start up and when you let the clutch out it would go backwards - the motor was running backwards.
  3. Hi there - I suspect you have sheared off the woodruff key and it will intermittently work. I have see similar issues on a DT200 and a DT 175. Just slide of the wheel and make sure its intact.
