Alex
Admin
Everything posted by Alex
  1. Alex posted a topic in The Bar
    Happy Birthday Seven
  2. Well if i had a carbon frame i would defo put some frame mushrooms on
  3. Alex replied to MT-01's topic in Naked
    Took em a while to get them out, remember seeing them well over a year ago in the paper
  4. Alex replied to Beezkneez's topic in Yamabyss
    All i can say is what the f**k! If you want a good CD buy Loveslapped by Jay-J, its an oldish funky house CD
  5. The 750s are hydraulic
  6. Wouldnt worry about the steering luck mate they dont do shite, to be honest. Get your self a proper lock and chain
  7. Alex replied to Beezkneez's topic in Naked
    Yeah the missile launcher is now on the back of my bike, and has the sorted disks on the front, and is booked in for friday so fingers crossed Good luck to both the bikes
  8. If my bikes not sold by then will have a last trip
  9. I wouldnt recommend putting water in at all, but surely hot is better than cold as it would evaporate out quicker Flush out with a flushing agent, and then fill with oil
  10. oil
    Alex replied to chip2222's topic in General
    Good luck smitty
  11. Alex replied to MIKEY's topic in Yamaha Workshop
    Never knew you had a SP
  12. I hope thats a joke! as how the feck would you get the sawdust out
  13. Alex replied to Smitty's topic in The Bar
    Dont you mean Procks
  14. The type of oil will depend on your bike, and never fit a cheap filter!
  15. Alex replied to MIKEY's topic in Yamaha Workshop
    The two ive seen have both run pretty crap, compared to how my standard runs, i always thought all flat sides ran lumpy?
  16. oil
    Catch 22
  17. Alex replied to 4l0's topic in General
    Race Developed
  18. toy
    Alex replied to gaz's topic in General
    THinking of off road bikes, i so want another motorcross
  19. Yeah i like to lean over the tank
  20. oil
    No probs mate, hope you understand my waffle. As for a filter maybe a gun would be better
  21. My YZF750 has span adjsutment, would one of them fit? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...7968968262&rd=1
  22. Alex replied to MIKEY's topic in Yamaha Workshop
    Yep thats because there flatsides, if you want it to run nice and smooth you can swap with mine
  23. oil
    Right heres my stab at it then! Cars compared to bikes demand long service intervals so the oil has to be designed for this. The oils therefore have friction-modifiers and other additives in to keep them working for a longer time If you use car oil in your bike, the friction-modifiers cause a problem because most motorbikes have a wet clutch. Car oil gets onto the clutch, the friction-modifiers get to work and you'll end up with a slipping clutch. Bike oil doesnt have friction-modifiers, so you dont get this problem. Im pretty sure but oils for wet clutches have an MA label on it. Another thing to consider, is that car oils are not designed for a gearbox. The meshing of the gears shears the oil which does not happen with a lovely smooth crank. Which causes car oil to foam, losing its lubrication. Motorbike temperature flucuates a lot quicker than a car. Larger mass of the car engine combined with the larger amount of fluids and a sealed engine bay mean the temp changes are less pronounced. The higher power output of a bike engine compard to size means higher temps with less fluids and metal to absorb the temp change, causes rapid change in temp during operation. Which means the oil needs a better temp tolerance to cope with this. Finally car oils tend to be very thin and will burn off and some may get past the rings and burn off. And on top of all this a motorbike revs 4 times higher than cars. This site gives good info regarding oils http://www.chris-longhurst.com/carbibles/i...eoil_bible.html
  24. Alex replied to yammie girl's topic in Yamabyss
    You sound as bad as Eddy already!
  25. Yeah help save the bandwidth
