Everything posted by Alex
Differences between DT125R and DT125LC
Use a bike cable, and gear lever, so you can manually open and close it, otherwise you lose bottom end power
- There's No Excuse for it you know!
- Happy Birthday Seven
Enough to make ya Drool!
Well if i had a carbon frame i would defo put some frame mushrooms on
- MT-01
Underground song
All i can say is what the f**k! If you want a good CD buy Loveslapped by Jay-J, its an oldish funky house CD
thundercat clutch lever
The 750s are hydraulic
DT 125 R Steering Lock - Problems
Wouldnt worry about the steering luck mate they dont do shite, to be honest. Get your self a proper lock and chain
- MOT time
Yamaha Day at the Ace. 24th April
If my bikes not sold by then will have a last trip
Bike not running well.
I wouldnt recommend putting water in at all, but surely hot is better than cold as it would evaporate out quicker Flush out with a flushing agent, and then fill with oil
- oil
- YZF 750SP CARBS
I hope thats a joke! as how the feck would you get the sawdust out
- OI! Own up!
What kind of Oil in an XJ600n
The type of oil will depend on your bike, and never fit a cheap filter!
YZF 750SP CARBS
The two ive seen have both run pretty crap, compared to how my standard runs, i always thought all flat sides ran lumpy?
- oil
- rd forum
- toy
Be AFRAID ..... be VERY Afraid !!!
Yeah i like to lean over the tank
- oil
My YZF750 has span adjsutment, would one of them fit? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...7968968262&rd=1
YZF 750SP CARBS
Yep thats because there flatsides, if you want it to run nice and smooth you can swap with mine
oil
Right heres my stab at it then! Cars compared to bikes demand long service intervals so the oil has to be designed for this. The oils therefore have friction-modifiers and other additives in to keep them working for a longer time If you use car oil in your bike, the friction-modifiers cause a problem because most motorbikes have a wet clutch. Car oil gets onto the clutch, the friction-modifiers get to work and you'll end up with a slipping clutch. Bike oil doesnt have friction-modifiers, so you dont get this problem. Im pretty sure but oils for wet clutches have an MA label on it. Another thing to consider, is that car oils are not designed for a gearbox. The meshing of the gears shears the oil which does not happen with a lovely smooth crank. Which causes car oil to foam, losing its lubrication. Motorbike temperature flucuates a lot quicker than a car. Larger mass of the car engine combined with the larger amount of fluids and a sealed engine bay mean the temp changes are less pronounced. The higher power output of a bike engine compard to size means higher temps with less fluids and metal to absorb the temp change, causes rapid change in temp during operation. Which means the oil needs a better temp tolerance to cope with this. Finally car oils tend to be very thin and will burn off and some may get past the rings and burn off. And on top of all this a motorbike revs 4 times higher than cars. This site gives good info regarding oils http://www.chris-longhurst.com/carbibles/i...eoil_bible.html
