		TW 125 CDI BEEN CUT OPEN!!???
		i was doing some stuff to my bike today and i had the panels off.. got into the bit where the fuses are etc.. moved the cdi and noticed it had beed cut open around the top so you can remove the shell revealing the guts(circuitbaord i guess?) any ideas? has it been modded? is there a mod... help lol
		TW 125 VALVE SETTINGS???
		its got 24000 and yamaha said it should have a 24000 mile service they also said the tappets sound loud when i took it to them (i got them to come outside and listen lol) so i should book it in they said! but im cheap lol. so im doing it myself... i have done the oil and filter cleaned the carb and air filter new plug blah blah... i just need to know where to set the valves/tappets? cheers
		hi can anyone help me with the valve settings? the manual says: inlet: 0.05 - 0.09 exhaust: 0.11 - 0.15 where do i set them? cheers
		TW 125 experts needed!
		thanks mate.. i have done a service myself as in oil, filters, plug etc and im looking into doing the valve cleareance... what do you mean by 10.5 on the jet? please explain. and if you know anything about valve settings please answer my original question on valve settings... many thanks
		hi, i just got my tw 125 and was sorely dissapointed when it only did 50mph lol so im on a mission to help my 125 be a real 125 or at least do what its capable of lol firstly iridium spark plug? good idea? or stick to standard ngk dr8ea... i want to know if you can do anything with the tw exhaust? can i remove the baffle? i want to add a filter to the crank case breather and a k and n style cone filter to the carb... will i need to rejet or will get away with just raising the needle up one notch? i dont want or expext 100mph!!! LOL. i would just like it to go 60 easily and not loose all its power on the slightest hill... after all this is a 125 and can easily do 60 - 70 theoreticaly. and its a four stroke so it should have more consistant torque. everywhere i look all i see is people saying they want their tw125 to go faster and have more guts and all i see is no answer... there must be some way! and an easy one at that! so, basicaly if i add a k and n filter and free up the air flow to and in the exhaust(remove baffle/restrictor?) surely this will take it closer to where i want to be? also would it be worth just putting a 55 tooth sprocket on i know this will make the low gears short/accellerate faster but maybe it will give more power to the infamous fifth gear which does nothing!? or should i go smaller in size? maybe 45 tooth rear sprocket? what effect? also i have seen these:(type the following into ebay) SCOOTER 125 PIT BIKE RACING CDI KYMCO QMB i think it will fit they supply 2 different connections... good idea? lastly, in the haynes for the valve clearance settings it gives a tollerance of intake valve 0.05mm - 0.09mm and exhause valve 0.11mmm - 0.15mm... basicaly... wtf!? does this mean i can set the clearances to 0.09 and 0.15 and it will run fine on stock set up? possibly with better performance? im not looking to spend money other that the filters... i know all the tw sites and parts sources but im going to work with whats there sorry for the long post and i thank you all for your help and time in advance. please help/advise. cheers
STEALTH_R6
Joined
Last visited
