2-Stroke Dan
  1. If it's the one with regular pipes, then there's a hole in the bottom of each exhaust (near the end), which gives access to the screw that holds the baffle in place.
  2. Yeah, it does look 'wrong', I think the fork legs have been extended (probably making it lethal to turn). Here's a pic of a proper one:
  3. When you say "pops", do you mean it backfires thru the carb? If so, I'd check the reed valves and/or crank seals.
  4. Found this pic: weird looking bike...
  5. Great advert! My first 'real' bike was a blue 100cc LS3, just like the one in that clip. Ah, those were the days...
  6. The '75 & '76 (A/B) DT400 & DT250 all used the same flywheel/ignition. Other years might work too.
  7. Here's some more Yamaha model codes: http://www.merrittmotorcyclesalvage.com/yamahamodelcodes.htm http://www.dropbears.com/m/models/yamaha/modelcodes.htm
  8. 2-Stroke Dan replied to 2-Stroke Dan's topic in Classics
    I'm using Photobucket to store my pics. You can easily cut'npaste the IMG code for any photo straight into your post, no need to use the 'attachments' feature.
  9. 2-Stroke Dan replied to 2-Stroke Dan's topic in Classics
    Thanks a lot for the links, just what I need! Hi nets, Thanks for the advice, I've decided I'm going to go for it (even though I've no room for another bike). Have you any pics of your DT1? I wish I'd asked for advice here sooner, you guys have been very helpful . Hopefully I'll have some resto pics to share over the winter
  10. 2-Stroke Dan replied to 2-Stroke Dan's topic in Classics
    Damn, missed out on them (sold for $52.01). I guess I'll just have to keep looking...
  11. 2-Stroke Dan replied to 2-Stroke Dan's topic in Classics
    Thanks a lot Chris, I'll check out those links. I think I will go for it, as they're hard enough to come by this side of the pond. It's a US import, but the owner claims it's a DT1 because the year of manufacture is late '71 and the VIN starts DT1F. I think it's a DT2 because the engine has reed valves, the engine casing has 'YAMAHA' indented (the DT1 was raised) and the rear light & petrol tank look to be DT2. Also, the first DT2's had the DT1F prefix. If anyone can help to positively identify it from this pic, please do: It needs a paint job (candy orange), front fender, rear shocks and a new seat.
  12. 2-Stroke Dan replied to 2-Stroke Dan's topic in Classics
    Thanks a lot Harmonicaman, much appreciated! Now I just need to win the auction...
  13. 2-Stroke Dan posted a topic in Classics
    Hi everyone, I'm a big fan of Yamaha 2-Strokes from the early 70's, especially the AT2, DT2, & DT360 singles (great memories). I've kept an eye on ebay & gumtree for ages, but nothing suitable/affordable ever showed up. Then, by accident, I discovered a 1972 DT2 sitting in a garage just a few miles from my house! . I almost bought it there and then, but I decided to check on some parts availability first. The bike is almost intact, just missing indicators for road use. It runs, but needs constant throttle and is hard to start. I noticed some fluid on the flywheel, so I reckon that one (or both) main seals are blown. I've searched the net (bikebandit, etc) but I can't find anywhere with seals in stock (I guess a lot of DTs blew seals). Is there anywhere I can get oil seals to fit this bike? would seals with the same dimensions (for an outboard motor) be suitable? Thanks for any help/advice you can give.
