dt400driver
  1. hello can`t type for S--t ! lol as i was saying swapped mpotors trying to get out of pulling magnetos and backing plates from swap!trouble is theres an extra wire on the 75 lighting coil You have a yellow with white stripe,a green with a red stripe and a green wire with a white stripe this is the extra one What to do besides change whole harness or magneto plates?also i cant find a 1976 DT400 wiing diagram for DT400C. Help?
  2. hey Greg, I recently restored my shocks on 76 DT400and it sounds impossible butnif you lower the shock to the lowest setting You should be able to compress the spring enogh with the help of a screwdriver to get the keeper off of the eye! hope that helps.
  3. HI ,I`m trying to figure out if I have the correct ignition switch for my bike(bought off of E-Bay)It is a chrome covered switch,and it has 3 total positions,off 30 degrees to left ,on straight up and a third position 3o degrees to right,I know on 73 and older enduros the headlights were activated by this third position.I do`nt have a manual so Im trying to find out!Also I turn my lights on by sliding switch on left handlebar mount above turn signals! Help!!
