Drunkenmunky04
Everything posted by Drunkenmunky04
  1. The R6 and Fz6 have essentially the same engine cams differ but the restrictor on the fz6 was a plate mounted to the side of the carbs which stopped the throttle openin fully ....... If you notice that there is not a lot of travel or twist on your throttle it could be the same thing and the best part is you could have it off an riding in twenty mins... what a difference!!!
  2. Clunky gear change is normal on the FZ6 ..... dont drive your bike wit those warning obviously there for good reason maybe oil pressure problems .... don't fuck up ur engine bring it in your good for 3 years warranty.
  3. I had a similar problem wit an fz6 .... same engine as the r6... turned out it was a throttle sensor that needed replacing maybe check that too
  4. Drunkenmunky04 replied to ginger's topic in Yamaha Workshop
    Shouldn't make a sound.... you mite find that one of the brake shoes isnt fittin rite. they can slip of a runner when there bein fittin work fine but move more than ideally its easy to pull off a caliper an check. If i remember rite its 2 size 12mm bolts per side... should ye find one loose open the caliper undo'in 2 more bolts and realign them before closin it again... if it aint that i cant help
