bill1800
Everything posted by bill1800
  1. Hi there. This was a simple fix.....changed the spark plugs and solved the problem...thanks for the help.
  2. What do you think about the gas leaking out and the reserve not functioning?
  3. Thanks Jim and will check out the carbs and do a comp test and will let you know how I make out...thanks again.
  4. I just checked the choke and it seems to be working properly. Just had it out, drained the battery on it trying to start it cold 4 C. After I heated the engine with a small radiant heater and charged the batt. it started, but there was a strong odor of fuel, so it probably is flooding. At first I tried full choke that is when it flooded I guess, I took the choke off and held the full open and that is when it started. Any ideas
  5. Hi there. I own a 84 xj650. Very nice bike but I am having a problem starting this when it is cold out. Basically if I want to start it when the temp is below 10 C I have to heat the engine up and it will start no problem. If I dont warm it up it will just turn over and wont even try to fire. Once I have it running it runs like a top. Can anyone help me with this issue
