Robbie
Everything posted by Robbie
  1. Robbie replied to robert's topic in The Bar
    Robert the clicking you hear under the seat is actually the fuel pump priming it's self so you know that works. Try jump starting the bike using a car, I've done this and no harm has come of it. If you get it started then go for a long ride to charge the battery. As far as other parts of the electrics go its a long job but you need to check every connection to see if they have worked loose. Failing that then look at relays. If that fails it could be something like a buggered starter motor.
  2. Robbie replied to Robbie's topic in The Bar
    Was carted off in an ambulance so don't even know what the bloke looks like. If I was able to talk to him at the time I would be up for actual bodily harm or manslaughter now anyway.
  3. Robbie replied to Robbie's topic in The Bar
    Cheers guys. Unfortunately looks like the bike is going to be written off as according to the police there was oil and petrol all over the road. I havn't seen the bike yet but hopefully ill be able to salvage some stuff off of it.
  4. Robbie posted a topic in The Bar
    Well guys just thought I'd let you know that my R6 dream ended on Thursday around 13.30. I turned into a side road from the main I'd just been on, went passed a van (which I thought was parked up) that then moved out and side swept me into a parked car the other side of that road. Bike looks like it will be written off but don't know yet as I was carted of in the back of an ambulance. I don't know what hurts more my injuries which aren't that bad to be honest or the void in my life where my bike was. Regards
  5. Robbie replied to a post in a topic in The Bar
    Happy birthday mate hope ur having a good one Regards
  6. Robbie replied to giggles's topic in Naked
    I have a blueflame Evo 3 titanium on my R6 and it sounds sick, it pops nicely on the over run and gives massive power gains, plus good value for money as well.
  7. Robbie replied to yanto's topic in The Bar
    The R6 is an arse to work on cos of the way yamaha have crammed everything in. Just changing the brake lines the other day took a while cos of ill placed bolts, and though I do most things myself on the bike I wont try that.
  8. Robbie replied to Tomo's topic in Naked
    There was a tuning company that at one point tested all the different fuels you could get for power gains and throttle response. I cant find the website but the findings were: BP Ultimate and Shell Optimax / V Powergave the same power gains over normal fuels and believe it or not Tesco 99 gave the same gain in performance again on top of the BP and Shell fuels. As far as my tank goes the fuel light comes on around 110-125 miles on average. I have managed to get that as high as 160 miles before it came on but only the once. Regards
  9. Robbie replied to yanto's topic in The Bar
    Whatever happens never ever use T-cut cos ill come and find you and chop your arms off. It contains Ammonium (NH4) which is very corrosive almost like bird lime. I use diesel to get rid of other oil deposits as you can leave it on paint work with no problems - just be careful near the brakes. As far as muck off goes follow the instructions and there should be no problem, leave it on for too long however and it will eat into the pint work. Regards
  10. Robbie replied to yanto's topic in The Bar
    There are no problems as such, there will be a chatter from the oil pump chain but it isn't a worry the only thing you have to worry about is the 24k service which means you'll have to shed out around £400 for it. Regards
  11. year 2000
  12. cheers for the swift reply. Would you recommend doing it or is it not worth it.
  13. Ive been told that some floating disc designs mean that bumps make them rattle a little hope you can find the problem and sort it.
  14. Hi guys seen that on bikes that are used for racing and track days that people have put the suspension forks through the yokes in order to lower the front end - what benefits and disadvantages does this give the bike as im looking for more cheap mods to do to the bike. Regards
  15. I know there has been talk of 118bhp at the rear wheel in stock not sure about torque though
  16. Happy Birthday mate. Hope you have a good one whatever or wherever you end up.
  17. Whatever sort of basin you use petrol is one of the better solvents to use as it cleans but doesnt strip paint. wear gloves tho.
  18. Robbie replied to st414's topic in The Bar
    Get michelin Pilot powers they are the sex. They turn in really easily and give awesome grip. Regards
  19. Robbie replied to Ghostie's topic in Naked
    Will look into it tomorrow as there is a yamaha dealer 100 yards from where I live. Regards
  20. Robbie replied to kev's topic in The Bar
    Congratulations to the both of you. Make sure you find a good firm to help you get through your test and don't make silly mistakes, they are expensive. I didn't put my feet down at a stop line - I have good balance and knew the area so went into a gap that presented itself. Regards
  21. Robbie replied to Sanity Assassin's topic in The Bar
    Don't really happen mate but im up a meeting up if you want. I live in Southampton, where you based. Regards
  22. Robbie replied to Ghostie's topic in Naked
    Guys just to let you know that was for the earlier model R6's so may not work if it doesn't I can easily find out for you. Regards
  23. I assume you mean disengage the clutch as if you don't this would be the cause of the problem. If you are doing everything correctly it sounds like you may need to overhaul the entire clutch mechanism or at least clean it as the plates maybe sticking. Regards
  24. Robbie replied to Tomo's topic in The Bar
    Mostly yanks (no offence to guys here) who are interested in allowing their skins to be pealed, getting the front wheel in the air and adding as much weight in the form of chrome as possible to their bikes. Having said that there are a few good posts but a lot of crap. I've been a member there for 5 months and have only posted a coupled of times and drop in only once a week tops. Regards
  25. The guys that got me just before xmas seemed annoyed that they had to nick me. I was doing around 65 in a 40 on a cold winters eve and Id just travelled from Brighton to Southampton so you know I was cold, very cold. Anyways 10 mins from home these cops pull me over and chat to me and only do me for 56 in a 40. They could see I was cold and actually took the piss out of me as I have a MotoGP race waterproof which looks like a gimp suit. Seems stupid having a laugh with the guys that are giving you 3 points and a £60 fine. Regards
