vtrsp1nutter
  1. hi its been sorted now .
  2. hi jim thanks for trying to help ,but i have now sorted it at long last . someone let me take there bike apart .how kind . willl post some picture later on so you can have a look . thanks again .
  3. i am using the older fzr motor and not the r1 engine . they are a lot stronger and take the abuse of engine conversions . i hope to turbo this engine too . but i need it to run first . hopfully soon some one can help . i was just wondering if you could put a new cdi system on the engine like a fzr 1000 1992 version ? or would the flywheel pick up points be different and alter the stactic timing ?
  4. hi can anyone help i need to know what colour wires go into the cdi unit and the position they are in . i dont need to know the fuction as i know what every wire does i just need the colour order in the plugs . the cdi unit code is 2gh-10 ,tid14-57 . many thanks if you can help
  5. yea i know if only i had the plug then it would be so easy .
  6. hi i have build a number of bike engine conversions , i will post some pictures at a later date . i am trying not to buy a loom , but it might have to come to that unless anyone can help. i have big plans for this project as i have made a number of turbo convrsions too . the last fiat panda conversion i did it was running a turbo charged gsxr 1000 motor .i do hve a wiring diagram but with out knowing where the wires goes in the cdi i am lost .the conversion is very easy to do but you have to be good with a welder as you have to make new down pipes and propshaft . you can buy adapters to accept the prop shaft from the drive sprocket . i guess it wont handle very well but i have a set of coilovers just to handle the corning forces just so it wont topple over .
  7. please help i am in the process in building a bike powered rascal van . the engine is in and all i need to know is what wires goes where in the cdi unit . i have no plugs which is a problem but if anyone knows which terminals are which would be a great help .the cdi unit is tid14-57 2gh - 10 the plugs look like this . there are two plugs . please please help . ----------------------------------------------------------------------------- a---- b-----,,,,,,,,,,,,,,,,,,,,, e ----- f---- g----- c---- d-----,,,,,,,,,,,,,,,,,,,,,,h----- i----- j----- ------------------------------------------------------------------------------------- i have lettered them to make it a bit more easy to understand .
