sierrafox17
Everything posted by sierrafox17
  1. yeah you were probably dead on of course, but hey thats life. i figured if i kept the mixture rich it would be ok, but i was obviously wrong. i think im just going to give up on old bikes early, and start saving up for a newer 4 stroke.
  2. hey all, my 78 dt 175 died after a day of biking, and we broke it down and found the piston and gaskets were fine. what we do see it that the connecting rod is next to locked up, so its really hard to kick over, even with the piston out and in the open. so the bearings went? we may just place the whole bottom end but any insight will help thanks everyone
  3. south boston, mass why?
  4. no unfortunetly i bought it without a carb or any carb components
  5. ok so i have put on a vm24 roundslide mikuni onto a dt175e. the probelm is, im a total newb to bikes (only worked on trucks until now) and i have no idea how to adjust this thing so that it runs right. a fellow yamahacluber informed me on the settings: Main Jet 140 Needle Jet 0-2 Jet Needle 4J13 Clip posn 3 Pilot Jet 22.5 Air screw 1 14 turns out Float level 21mm but that doesnt really mean alot...so could anyone out there walk me through this? maybe even a couple pictures? thank you in advance.. rob
  6. i just got off the phone with a couple different guys, and they said that as long as i use premixed fuel then i dont need the oil injection, since its 2 stroke that makes sense. they said that the vm24 should work fine.
  7. MIKUNI VM24 ROUNDSLIDE CARB Mikuni True VM24 Roundslide Carburetor. Measures 24mm at intake manifold. Uses 35mm rubber boot intake. found this on ebay 80 bucks new. this looks right to me, but im still new to bikes so i want to be absolutely sure. thanks for all the help ~rob
  8. so i bought a dt175 in great shape but with the carb removed. now, since i dont have the old carb to compare, i am having alot of trouble finding a carb to fit. can anyone give me some info about where to start? im looking for any carb that fits, what do you think? ive only reason worked on trucks till now so dirts bikes are somewhat new to me. thanks for the help. ~rob
