Scott9096
Everything posted by Scott9096
  1. Thanks ill have a look soon and see if it helps at all
  2. I can see 2 screws one with a spring behind it and the other is set back in a brass fitting which screw is which.
  3. My sister has a Yamaha CS50 Jog R and it keeps cutting out either when she is idling, it was recommended that we change the carburetor,which we did but it still hasnt solved the problem. When it does cut out it wont then either kick start or electric start unless we pull back on the throttle at the same time as starting it. I thought it might be something to do with the idle jet but as im dont deal with mopeds much i wouldnt have the foggiest where to look for it and i cant find any diagram to help. I just wondered if anyone could help, ie with another diagnosis or a description of where to look for a solution
