Everything posted by neversaydie
		motorcycle care over winter/useing when can?
		Done a foamy..
		£250???? Absolute bargain, cant lose even if you break it for spares, cracking buy, well done
		Need some advice please xj6
		Be careful your fuel doesn't go off. Unless your using "Super", your petrol will contain ethanol, which absorbs moisture, the longer its in the tank unused, the more likely you are to have problems firing it up next year. Not likely to be a problem if the bike is fuel injected. If its a carburetor fed motor, then you'd perhaps be best draining the carbs As an alternative, I believe that their is an additive that you can put in the fuel to prevent it going off, buggered if I can remember what's its called at the mo Oil the chain so it doesn't go rusty while its standing Make sure that you've washed all of the road salt off
		Spark goes off while riding - Virago xv125
		and if I squeeze the clutch and release, it starts again Theres a clue then Id be tempted to check out the clutch switch/side stand switch/kill switch and associated wiring
		One from the golden era???
		The passing away of sports commentator David Coleman, reminded me a match I saw donkeys years ago on the old black an white valve set, from the days when men played soccer http://www.youtube.com/watch?v=T5jVMSlpZhg
		is it one or bothcylinders?
		Fz600 Gulf
		Must be Radian day, heres another http://www.ebay.co.uk/itm/YAMAHA-MOTORCYCLE-radian-600-1986/141142243464?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D16581%26meid%3D3558664586956828188%26pid%3D100033%26prg%3D7839%26rk%3D4%26rkt%3D4%26sd%3D291033905757%26
		Fz600 Gulf
		Known as YX600 Radian over here, early models had brushes for the alternator, later ones brushless Cracking little bikes, couple for sale over here on the bay http://www.ebay.co.uk/itm/Yamaha-XJ600-YX600-RADIAN-mini-V-Max-/221313157388?pt=UK_Motorcycles&hash=item33874ac90c http://www.ebay.co.uk/itm/1990-YAMAHA-YX600B-RADIAN-8956miles-MOT-Taxed-Swap-swop-p-x-Try-Me-/291033905757?pt=UK_Motorcycles&hash=item43c2f8fa5d
 - New toy :D
		XJ6S Auxiliary light
		Not sure what lamp type it is youve got or if it comes out back or front. If its front, you can use something like this, it just pushes onto the top of the lamp, twist and pull. You can make your own dead easy with a short piece of flexible tubing http://uk.farnell.com/dialight/506-0045/bulb-installion-removal-tool/dp/1193351
		Fitting r6 subframe to fzr 400 1wg
		Not guilty
 - New toy :D
		Crashed today - all ok
		Pleased your not injured, and bike ok Coldest morning of the year around here too this morning, pavement outside the house was sheet glass, but got onto the road ok Signs to look out out for when its like this Roadside hedges: ice thaws slowly(if at all) as the low sun cant get onto it Under trees: same as above Under bridges:same as above Kep off the big white arrows and letters Keep of the white areas of zebra crossings People washing cars at the roadside
		Project 86 FZ600 - "Black Yamba"
		Be very, very careful if you take the alternatior cover off. The brushes and the bakelite type material that they sit in can be easily broken. Make sure to pull the cover off straight, and put it on straight, while sliding the rubber cable grommet out of its slot
		Stripping paint from cast wheels
		chandlers sell a good stripper too, fucked if I can remember the name though, but you could ask em
		help pls to get back my gears
		Normally there is a mark on the splined shaft that needs to line up with the split in the lever Ride it for a couple of days, if its still good, then mark the end of the shaft with a centre pop, where it lines up with the split. That wont wash off
		X-Factor
		Fraid thats TV today Groucho Dominated by cooks/antique dealers/reality?tv/so called talent shows/banal quiz progs yah yah yah "what does the pressure pad say" Daytime tv that trots out soap stars? as celebrity guests Loose Women? fuck me its the pits, underworked faded gobby knowall fuckalls with an endless procession of? - youve guessed it, soap stars as guests But people watch this shit And its mainly women Emancipation has bred a generation of mindless wanabees Emily would turn in her grave
		Adventure time...!
		Oopps, my mistake, thats what I meant
		Adventure time...!
		Well done. Apparently, the technique for lifting a fallen bike is; back to the bike down on your haunches one hand on the uppermost bar tuther under the seat or similar straighten legs, and up goes bike never had to try it though Is that how you lifted it?
		SORN....What's the deal?
		Ps is restored
		Sorry chas, looks like I've lost my (lease fill in the blank)
		Aye, the move to the "cashless society" forced uon us by governments has oened myirad oortunities for crooks. it was suosed to reduce remove the risk of eole losing their money, but far more is lost now to criminal activity than was ever lost whewe were aid in cash Also, the banks get hold of your money quicker, and hang on to it longer, so they can gamble it away in much larger quantities
		Who needs brakes?
		This the one? http://www.dkmotorcycles.com/used-spares/_177927/124876/ Ouch££££££
		as happy as a pig in s**t :)
		Pleased for ya, enjoy
		Naah, just breathe deeper, it'll go quicker
