neversaydie
Everything posted by neversaydie
  1. Looks like it passes over the carbs and under the tank, so maybe connect onto the carbs at the rear perhaps/
  2. After 3 years, I would try a complete clean out of the fuel system, tank/filter etc etc, then fresh fuel in
  3. neversaydie replied to Mrghiki's topic in Appearance
    As above, check the chain for stiff links. Also check the sprockets for hooked teeth, make sure the front sprocket is secure on the splines and the wheel bearings for wear. Is that a fazer? Early fazers had a problem with the front sprocket coming loose, they replaced them with a deeper one
  4. Yea, we did have a good un weather wise. I love it, wife hates it hot. You can imagine the disagreements, fans on/off, windows open/closed, too hot to cook etc etc, salads day after day
  5. Started of ok, plan was to buid a summer house down the bottom of the garden. That was kicked into touch as my youngest (33) got thrown from one of her horses and broke a leg. The old man had to step up and spent the spring/summer looking after 4 horses and the dog. Thankfully, shes now almost fully recovered. The accident meant that my plans for half a dozen trackdays had to be abandoned, so the recently fitted full fairing and power commander never saw track action. However, I did manage to get 2 days at Donny Park, one in sept and one in oct. I was dead lucky again with the weather on both, and had 2 smashing days out. The second was Leon Haslam trackday, and I went to both of his briefings, very informative about mass and balance. I cant claim to be anything special, just an old man trying to have a bit of fun, but I will say to anyone whos not been on track before, try it, its an absolute hoot and youll meet lots of great peolple
  6. Always start with the simplest, easiest, and cheapest checks first. Check for spark at the plugs, check that your getting 13 to 14 volts at the battery at around 3000rpm, no more than that. Go round the bike and check all of the earth conecttions are sound and clean
  7. Pretty much any sport touring tyre road tyre from the major manufacturers shoudl be fine. There are plenty of reviews available on the web. Asking for recommendations sometimes starts a tyre frenzy with every tom/dick/harry recommending soemthing.
  8. Wow, thats gotta be a toughie to take when youre in your mature years, with a lifetime of bad habits. Chin up, once youre into the regime/lifestyle, youll become accustomed to it. Ive several in my family/relatives T1 and T2, those that have adapted you cant really tell a difference, the one that hasnt is constantly having secondary problems. Stick at it and neversaydie
  9. Hi there. Always try the simplest and cheapest possible solution first. Try to nip the bolts up a little. I guess that you mean from the head gasket.
  10. I guess first port of call is the clutch adjustment. Check that and adjust as per the owners manual etc, then try again. Its always best to start with the simplest, cheapest, and easiest possible solutions. Your next stop will likely be the clutch area, sometimes an oil change can do the trick, again, simple and not too expensive
  11. Nice work
  12. Got to agree. Driving standards today are shocking, complete loss of control by the authorities, test unfit for purpose, motor cars too big and powerful, too many distractions, no-one prepared to wait or give way. Drivers compelte ignore traffic lights. Ive noted over ecent months that motorists at junction 25 on the M1 (suppose its the same everywhere) dont watch the lights that are in front of them, they are watching the next set around the island, when they swithch to amber they move off before their lights turn to amber. It happens at all of the slips, result is there is hardly ever a gap to pull into.
  13. Yes people do. Dont think there are many Virago owners on here. I have seen aftermarket exhausts fitted to them, and to be honest, I think the stock system looks better, plus you may have to faff about with the carbs, and on a 28 year old bike, the exhaust studs may put up a fight
  14. Superior to the mirrors. No blind spots or wind noise/buffeting. Gonna ride like this now
  15. Update time Alex. The kit arrived, instructions very basic, but easy enough for anyone with a little knowledge to install. Ive just installed the basic parts ie one rear camera and the monitor, just to see if its going to give me what I want. Camera is connected to the rear light feed for the live and earth, then plugged into the screen. Fired up first time. Kit also includes facilty for charging the screen battery via the bike, and a front facing camera (exactly same as the rear cam). Been out with it a few times now, no mirrors on and removed the riderscan. Camera scan angle is 140 degrees. I can now see whats directly behind, and as the cars slip off screen they come into view at my side. Only down side is the screen image is reversed
  16. Likely to change the air/fuel mixture, which may lead to you requiring to work on the carb to get the mixture correct. Unlikely to give any significant performance gain
  17. I am led to beleive that the rear caliper from an FZS1000 Fazer with fit with a little filing. Search the FOC club (Fazer Owners Club) for more info
  18. As above, you need to get the motor running before spending any money/time on it. Carbs cleaned, new air filter, fresh fuel, and I guess the battery will be shagged by now too. Make sure theres oil in the motor before you try to turn it over, ooh, and clean the plugs. That should keep you busy. If it fires up, dont ride it until youre sure the tyres arent gooing to blow, give them a real good look over. And check the brakes work
  19. Have a look at the forks just to make sure they look straight and parallel to each other. At the end of the day, its not going to drop into the corners like a sporty, but if the front end all checks out, then it is what it is, a cruiser, made for going in straight lines
  20. There are a number of Virago owners clubs worldwide. Sign up to a couple, there may be someone living close by to help
  21. Pop it on the centre stand, get the front wheel in the air. The bars should turn nicely with a light touch. If the bars are not stock, check the cable routes and make sure none are binding when the bars are turned
  22. Yep, bang on with the clearances. Torque for the nuts is 7Nm
  23. No, not bothered too much about recording, just for vision. Currently got the mirrors off and am using a RIDERSCAN parabolic mirror
  24. neversaydie posted a topic in General
    Yep, sold the cruiser a couple of weeks ago. Didnt need to sell, but 1500 miles in the last 3 years on it, seemed a shame for it just to sit in the garage. No regrets, gonna spend a bit on the Fazer now, powercommander to be fitted, likely to need new tyres this winter along with chain and rear sprocket. Going to have a look at a rear view camera set up too, so may be able to dump the mirrors
