neversaydie
Everything posted by neversaydie
  1. still the best looking of the small cruisers 2 tips 1) keep top side of the cleaning and maintenance, you'll get a good price when you sell it it on 2) dont have a bunch of keys hanging out of the ignition switch, they'll swing and chip the tank paintwork Enjoy
  2. same principle as Pipesnaps, for central heating pipes. Makes em look like Lego wheels
  3. neversaydie replied to Sacha's topic in Projects
    Nice work
  4. If all youve done is swapped the caliper, and not touched the master cyl, then it sounds like the piston is seized Was it a new caliper Did you check the piston slid in and out before fitting Why did you change the caliper
  5. I'm glad I don't drink in the same pubs Imagine being stuck behind you lot at the bar
  6. when you say that youve changed the front caliper, do you mean youve fitted another caliper, or changed pads You need to tell us ezxactly what youve done
  7. not a tit pic insight
  8. can you spin the wheel ?
  9. Dont think thats a collar mate, looks more like the shield off the bearing
  10. Check all other electrics for working with the bike running
  11. I think he's reffering to the inner race left stuck on the shaft
  12. or was filthy rich
  13. You have to remove the ring that holds the filter from the end of the seat, the numbe ris underneath the ring Old number is 2.3, new number is 1.5 Its my cock up, I've ordered the wrong seat, for 92 to 94 bike, should have been 97
  14. Nope, no numbers on the old seat. The kit is sold as carb repair kit, contains seat/valve chamber gasket and a very small o ring that ive yet to identify http://www.ebay.co.uk/itm/YAMAHA-XV750-XV1100-XV-750-1100-VIRAGO-CARB-CARBURETTOR-REPAIR-KIT-/120952875127?pt=UK_Motorcycle_Parts_13&hash=item1c295a6877
  15. Float needle and seat arrived today,. Checked against the old one before starting to fit The hole size in the new one is smaller than the hole size in the old one. Everything else appears to be the same Checked before buying, dont appear to be a range of sizes to choose from as with the jets Ok to fit? Any differences in performance as a result?
  16. Hmmmm, that looks a bit healthier Took it for a 10 mile run, seems fine Rigged up an LED indicator so that I can see whats happening while I'm moving, as I need to build some confidence back up in the bike, seems to work fine, all LEDs lit on the run
  17. Slow down a bit Get the bike first Ride it around, get to know it If, aftre a while, you want to change the pipes, then do, but there's nowt worse than buying a bike then stripping it for some reason or other, then having hassle to get it going right again, it''ll put you off if your'e not mechanically minded.
  18. http://www.ebay.co.uk/itm/Dtr-125-Carb-Removed-From-Running-Bike-Mikuni-Flat-Side-/231170922633?pt=UK_Motorcycle_Parts&hash=item35d2dc5889
  19. This is what your Highway Hawks will sound like
  20. The stock pipes are the best sounding on a small cruiser I ever heard, but its a personal thing The Highway Hawk pipes sound a little harsh and give the game away a liitle thats its a 125 Drilling holes in the stock pipes might mean some furtling with the carb/might mean an MOT failure Bear in mind that second hand stock pipes are rarer than an honest politician In my view youve 2 options 1) Leave the bike as it is, enjoy it for what it is, learn your roadcraft on it an pass your test, then move on to a bigger bike 2) Buy some aftermarket pipes, keep the stock pipes for MOTs (undrilled), pass them all on when you sell the bike on after passing your test Look after it and it will hold its price well
  21. Top man Lallasro Thats capitalism for you, inbuilt obscelesence I seem to recall someone else doing similar with a CDI unit a couple of years ago on here
  22. neversaydie replied to Stef-c-'s topic in Classics
    I use Photobucket, its a piece of cake. Upload your image into it, then just copy the IMG line into your post
  23. Hopefully, this has been the cause of my problem Crud on the filter, and a hole in it too Stripped both carbs down today, everything else looks fine
  24. Granbys are still in business, almost next door to the Tesco at the bottom of Bath Street, Ilson.
