philbrad73
Everything posted by philbrad73
  1. HI I'VE GOT A 98 THUNDERCAT IT'S STARTED MISFIRING AT 6000RPM AT IDLE AND 9000RPM UNDER LOAD (ALL GEARS) AT BOTH TIMES THE REV COUNTER NEEDLE DROPS TO ZERO FOR A COUPLE OF SECS THEN BACK UP? IT'S A CONSTANT MISFIRE AND WON'T ALLOW THE REVS ANY HIGHER SOME SORT OF INBUILT PROTECTION/FAULT CODE? I'VE FOUND A THREAD ON ANOTHER FORUM OF SOME ONE WITH THE SAME PROBLEM BUT NO ANSWERS? ANY HELP REGARDS PHIL
  2. HI I'VE GOT A 98 THUNDERCAT IT'S STARTED MISFIRING AT 6000RPM AT IDLE AND 9000RPM UNDER LOAD (ALL GEARS) AT BOTH TIMES THE REV COUNTER NEEDLE DROPS TO ZERO FOR A COUPLE OF SECS THEN BACK UP? IT'S A CONSTANT MISFIRE AND WON'T ALLOW THE REVS ANY HIGHER SOME SORT OF INBUILT PROTECTION/FAULT CODE? I'VE FOUND A THREAD ON ANOTHER FORUM OF SOME ONE WITH THE SAME PROBLEM BUT NO ANSWERS? ANY HELP REGARDS PHIL
