FLYIN BRIAN
  1. HG are not known for failing. It's more likely to be the valve cover O-ring.
  2. Full synthetic 10w50 for me. Was using 20w50 until availability became an issue.
  3. He had hiccups.
  4. Oe of those damaged nut removers may work. I've never tried one... Tricks that I've used: Cut the side off the nut with a hacksaw blade, either held in your hand or vice grip. You may find it easier to have the teeth toward you, cutting as you pull back.(disadvantages; slow, requirig patience/ lade is long and can damage other items) File the side off the nut. Refer to hacksaw blade Use a nut splitter. Turn the nut red with a torch. (disadvantages; may damaged surrounding items including gaskets. Clamp jaws of death, er, vicegrip on the nut and hope for the best. Pray. Your results may vary.
  5. Check your valve clearances. Ticking is normal.
  6. Charge the new battery with a charger if you haven't done so. New battery doesn't come fully charged.
  7. You have a bad ground (earh) connection. The extra resistance behaves like a higher wattage bulb.
  8. if i accelerate to much This sounds like fuel starvation. If you roll off the throttle slightly does it seem to pick up? I firmly believe you need a fuel filter. Only a matter of time before you run into trouble without one. It may already the cause of your trouble. You should check the fuel system to make sure there are no restrictions to flow whether dirt in carb, kinked fuel line or dirty petcock. Also make sure the fuel system is venting properly.
  9. I've heard of people strapping the brake lever t the handlebar and leaving overnight to let the air come up through. Never done myself.
  10. It's kept on with 2 sided adhesive. Fishing line or "cat gut" should do the trick. Use tape adhesive remover to get off the remaining bits. Rubbing alcohol will also work but reqiures more elbow grease. You can also just roll it off with the pad of your thumb. That take the most time but is suprisingley effective.
  11. 1100 all the way. This bike just loves to soak up highway miles. Cruises effortlessly up hills and into headwinds. Mine consumes an average 4.5l/100km. The 450 in the stable does the same mileage.
  12. This is a chain drive. Are you 100% sure the back wheel is not the culprit? I've see spacers on the wrong side making it impossible to get correct alignment.
  13. I would tend to believe it's your fuel pump priming.
  14. Do not use your torque wrench as a torque breaker. The only way to check a clicker is to use a solid beam torque wrench. A solid beam torque wrench is accurate a long as the pointer reads zero when you start.
  15. Any loss of back pressure will reduce fuel mileage. Take away enough and you'll need to re-jet(like completely gutted and slash cut).
