scott101smith
Everything posted by scott101smith
  1. hey guys i wonder if any of you guys can help me out, i cant seem to get my bike to idle, its a 98 dtr,its got a standard carb as far as i know, i just cant get it to idle at all, iv got the idle screw adjusted fully in but this dosnt seem to affect any thing at all the air screw is set at 1 and 1/2 turns out and the needle jet on the middle clip...once started it runs and drives fine but cuts out if i let go the throttle... could the coil affect this at all? the manual says the spark should be a big fat blue spark but mine is more a wee thin spark?!?! any help would be great cheers
  2. ok so looks like a strip down is in order for further invesigation.. cheers for the replys
  3. hi all im having problems on my 00 model dt125r i can go up the gears no probs ut its hard to go back down them i need to keep tapping at the lever... can anyone help as to wot would be wrong with it?? the clutch it working fine with no probs..
  4. yip guru you where spot on water pump was knackered as was seal and shaft.. so i got a new casing with good pump and seal thanks for all the help ... tho iv been told that my play in the bearing is mininal and nothing to stress over so il just replace it when im doin the bottom end... cheers
  5. hi guys im new here, im having problems with my engine rebuild on my dt125r its a 00 model, to start with there was water in the crankcase when i bought it but i never thought much of it as i was buying it to rebulid anyway, but now iv stripped the head and barrel off and checked the condition of the barrel and piston and all seems fine... but when i hold the con rod and lift i can feel slight play (up and down play) is this ok or do i need to replace bearings? the bike is for off road use only so doesnt need to be perfect.. and wot oil is best to use? cheers for any help.... oh and wot would be the cause of water in the crnkcase???
  6. hi guys im new here, im having problems with my engine rebuild on my dt125r its a 00 model, to start with there was water in the crankcase when i bought it but i never thought much of it as i was buying it to rebulid anyway, but now iv stripped the head and barrel off and checked the condition of the barrel and piston and all seems fine... but when i hold the con rod and lift i can feel slight play (up and down play) is this ok or do i need to replace bearings? the bike is for off road use only so doesnt need to be perfect.. and wot oil is best to use? cheers for any help.... oh and wot would be the cause of water in the crnkcase???
