TIGER9055
Everything posted by TIGER9055
  1. TIGER9055 replied to HalHark's topic in Naked
    It works...I installed it today. Only took about 40 minutes to put it in along with a new air filter. Even the color coding for the wires (you have to tap into a blue wire) is correct. Just follow the instructions. The only difference I know of between the 08's and 09's are the stock ECU map. Since the PCV adjusts + or - fuel based on the stock map, the 09 maps wouldn't really be optimized for the 08's. And you can't load the PCIII maps onto the PCV, so your best bet is to get the AutoTuner or customize the 09 map. Of course the 09 maps from the Power Commander website still work fine on the 08, just not as good as they could be. I have a full exhaust coming in next week, so I'll reprogram it once I get the new exhaust installed and I'll probably get an AutoTuner to go with it. Make sure to install smog block-off plates if you use an AutoTuner so it can read an accurate air/fuel ratio.
  2. TIGER9055 replied to HalHark's topic in Naked
    No, not here yet. Should come in on Tuesday. I ordered from McCoy Motorsports (www.tobefast.com). Although I'm not sure if they ship clear across the pond to you guys.
  3. TIGER9055 replied to HalHark's topic in Naked
    We'll find out. I couldn't find anyone else who tried this, so I went ahead and ordered a PCV for my 08. I'll make a note to post how well the install goes.
