cranny
  1. what grade of engine oil are you using, have you adjusted the clutch to the workshop book, if you are sure these are correct, then the centre of the clutch, inside the cover has a kind of mushroom plug to stem the oil flowing into the clutch assembly, if this comes out it floods the clutch and can cause what you have. Check this plug and make sure it is still fitted, sometimes it drops out and you find it at the bottom of the clutch cover when you remove it, carefull when you remove it not to loose it on the floor.
  2. hello, i have a 1986 srx600 and the voltage regulator needs replacing, the number on is 1JK 81960 A1, sh565, does any body know if this can be replaced by the 47x 81960 A, sh569a. this i was told was an improvement on mine, but need to know for sure. thanks, cranny
  3. thanks for that, i will check what the coils are reading, thanks kevin
  4. thanks tony, mine is a bit on the low side then. I may have to try another rectifier, Any body know how to check these charging systems. thanks kevin
  5. i have this L reg fzr 400 and the battery runs flat after a while. i have replaced the battery with a new one, checked the charging, it shows a charge of 14v at tick over,14.2 at3500rpm. Put the lights on and volts drop to 12.4v at tickover,12.8v at 3500rpm.This seems i bit low i thought, any body know what volts i should be getting. thanks cranny
