Gmac1690-R6
Everything posted by Gmac1690-R6
  1. what i would do mate, is make sure youre getting a spark from the coils, pull the coils out, remove spark plugs, and put them into the coils, and one at a time, turn the engine over and ensure there is a spark, if you are getting a spark, then you can check the fuel supply, remove pipes and turn over engine, you will have petrol running out. have you tried a compression test ? you need over 100psi to get an engine firing up, this would be a last resort i think, but could be an option, and handy to see what youre engine is doing ! another fault could be the fuel pump, make sure its pumping fuel, either remove it and run petrol through it, or get a pipe to it with some fuel in a can, check all fuses ! thats all i can think of mate,
