2000 DT125R electrical problems
All sorted now. Turned out to be the live wire on the ignition barrel. The connector has 4 wires, and the live crimp had completely corroded away! so ive bypassed it and put on a new connection. Job done.
Hi All, My DTR has sudden developed an electrical fault. Usually, when you turn the key, the neutral light will come on, and youll hear the power valve reset. Only now, no light, and no movement from the valve. The first sign of trouble i had was after starting the bike normally, then as i rode home, the indicators did not work, although my front/rear and brake lights were still working. Nearer home, the indicators started working fine. When i got in, i decided to check it out, and noticed that when i turned the ignition on, the neutral light either flickered or comes on after a delay, like there was a bad connection. This cause the relay under the rear mudguard to flick on/off rapidly, and also the valve to go a bit crazy. Ive checked the relay (which i dont know what it is) and even with that disconnected, the neutral/ign was still going on/off. Now it just wont turn on at all. Ive checked the battery which is fine. There is a fuse i installed right next to the battery as there wasnt one when i got the bike, that is also fine. Is there any other fuses on the bike or does anyone have any suggestions on what to check?
Plastic Fuel tank leaks. Can I repair it?
You could try Q-Bond, have a look in your local motorfactors, the kit comes with 2 powders, grey for aluminium and black for plastics. Its meant o stick anything to anything and oil resistant, not 100% sure for petrol thou but its worth a try, its about £12 quid a kit.
help: DT kick start not always engaging
Yeah, im gonna check with the bike shop tomorow. Ive printed off the pics and have marked the parts i need and have faxed it to them, ill ring up and get him to compare it with their system. Im basically gonna buy whatever clips/spacers are on either side of that spur gear, in other words, No.3, 4, and 5 if they all exists on my model.
Thanks for that, now you mention it, when i first investigated this, i took the cover off and found a piece of a spring clip, semi circle at the bottom of the crank case. Also, the spur gear does come off the back of that shaft. Judging from the diagram, the clip no.3 should be the last thing on that shaft right? in where the groove is, so therefore, it would retain the spur right? Thats what i need, THANKS!
I've looked, and can't see anything, but the manual is a photocopy and some of the pics are great. Will look into it again
One final problem I need to sort out. The kick start won't engage first time. I've had the cover off and hav e check the shaft, gear, spur gear and spring which all seem to be fine. The kick lever returns back to the top so I know the spring is working. What I have to do is flick the kick start a few times by hand, once I feel it engage, then I have to keep pressure on it, place my foot onto it then kick the bike over. Is there something that's worn or missing that would cause the start not to engage? The spur gear does slide back and forth on the end of the shaft, but I don't know what's supposed to move it into position. Can anyone help?
DT125R bogging down in top gear???
WOW man! what a difference! The bike just pulls and pulls! theres no hesitation into the powerband now, its smooth and the power is emence! It even pulls well in 6th gear now. So that all it was all along, plus the speedo wires. Thanks for the tips.
Well, after you mentioned the PV, i decided to take a closer look at it. According to the workshop manual, after youve turned on the ignition, the keyway is meant to line up with the hole behind it, well, min didnt! After a bit of adjustment on the cables, and looking up the exhaust port, ive reset the cables and now it lines up on ignition. Gonna take a ride out and see how she goes now.
How do I go about cleaning the power valve? Tbh I don't know what's been done to the power valve, I don't even know how many previous owners its had! I'm still waiting for my V5 doc. I do know the last owner disconnected the plug to the PV servo thou, and left it open. I've since reconnected it all up. I have seen the write up on adjusting the PV on dtr.net thou, it looks linda scarey but I'm willing to give it a go. Can you tell me how much rotation the valve has from closed to open? I've looked at the servo motor and that rotates about 90 degrees when I turn on the ignition. Is that all its supposed to move? Obviously that 90 degree then translate through the cables onto the PV itself. I guess ill have to take the exhaust off and see how much it moves and if it fully opens. Should it fully open and then close when I just turn the ignition on? I've noticed while riding, as I'm approaching 7k rpm, it seems to struggle past into the powerband, especially in the higher gears and if there's a head on wind. Thanks for you help.
Mine a W reg 2000 year. Well, today i stuck a couple of crimp connectors on those 2 wire and decded to try connecting them. It sems to be working, so my guess is im just gonna leave them connected. It will now go over 60 mph, but i do sometimes need to drop down agear as the powerband doesnt respond well in 6th gear from 7k rpm, ive gotta change up a bit later in 5th to keep it going. Anyways, it passed the MOT today and the bike is taxed so im all good to go.
Ive been reading up,these 2 wires may have went to a reed switch inside the clock, but its no longer there, on the DT.net website, itsays not to cut or disconnect them, but theres nothing the now. Should these wires be connected? are they joined internall in the reed switch and then the circuit cut when it hits 60 mph?
Behind the speedo, there are 4 wires. Blue and black go into the speedo and goto the bulb, however the black/white and red/blue wires dont go anywhere. They are just stick up into fresh air! they dont look as if they connect anywhere, i.e. the end have been cut clean (not frayed)and there are no connections inside the speedo for them. What are they for?
Hi all, ive just got my DT back on the road. I recently bough a 2000 year model which has had the reed valves done, and an exhaust. When accelerating, it fine and goes no problem, but when i change up into 6th gear, the bike no longer pulls in the power band and begins to slow. If i drop it down to 5th, i can pull away upto 100 kph, but as soon as i got into 6th, it starts dropping speed to 60-80 kph. I feels as if its bogging down. Any ides?
Need Urgent Help fixing up DT125R 2000 plate
Thanks for the help. Ive removed the kickstart shaft and the spring has snapped, so i guess i need a new shaft. Ive found what looks like a small nipple where the carb is, just after the air box. I guess thats where the small tube goes. Has anyone got a workshop manual for the bike?
KevShek
Joined
Last visited
