jockspark
  1. hi my mate has the same problem with his virago had been stood for a couple of weeks we looked i the manual shows you how to check it remove cranck case cover ect,ect the clutch should only turn in one direction bike shop want near on £400 to do it anyway to the point there is a site called wemoto they do a starter clutch repair kit £25 (for the virago) you will need the manual the only specialist tool we had to get was a puller to take the flywheel off to get at it hope this helps and goodluck
  2. jockspark replied to forddude's topic in Yamaha Customs
    thanks for the reply the bike runs well plugs ect ok it has been restricted
  3. jockspark replied to forddude's topic in Yamaha Customs
    hi i have a 535 had it 4 years my mate just bought one sounds great but he has the same thing wont go over 60/65 how did you solve your problem ie was it resticted ? how did you derestrict it ?
  4. jockspark posted a topic in Yamaha Customs
    hi lads and lasses i need some advise i have a virago 535 when i try to start it the starter motor just spins allmost sure this is the starter clutch problem local shop wants ££££££££££££££ to replace clutch hunted the net found a starter clutch repair kit i have the haynes manual any hints tips or advice would be welcome thanks pat
