gorilaz
  1. Went through all cable,check the ignition switch for corrosion,fuses ,socket nothing.Everythig look OK. i wonder maybe cut off starter relay broke? what exactly CDI ignition box do? If the Cut off starter relay faulty, is it possible to start bike either push or press an ignition button?
  2. the engine kill switch off position, always start off any stand.gear box netural, i tryied pull the clutch nothing at all
  3. BIKE stood for a week untouch, it is dry now. Went through all wires, fuses, sparks, look OK. Oil and petrol Full. Lights, Indicators work fine. i believe battery is good. Gears on neutral. you turn the key everything OK, then you press the ignition and NO SOUND/ NOTHING just the oil and petrol light show up
  4. Last week i Jet washed Yamaha Fazer 1999 model. Right after that oil and petrol warning light come up which prevent me to start Fazer bike, unless i push the bike - have no problem then. i belive, i have electrical problem. anny suggestion?
