Everything posted by crowtoms
175 MX Gear Shift
The gear shift lever is badly worn making gear change erratic and jerky, I cannot seem to remove it from the spindle, I release the nut and take out the retaining bolt but the arm will still not come off, I do not want to force it off, is there a knack to it..??
DT175mx
Now got stator coil fitted. Bike will not fire. Checked carb, Exhaust, Bore, Electrics.. I think this one is a gonner. How the devil can this thing run.?
DT 175 MX Stator Coil
Can Anyone HELP..! It seems the stator coil has packed up on My 175MX. Has anyone got a spare, or can they be re-wound. Who can do this, Where and how much.. Thanks Tom.
DT175MX Oil Change
Can I bung in a small amount of flush and run until warm then drain..?
175 MX WILL NOT KICKSTART
OK. I will call in my local bike shop..? Oldgitonabike can you help with other question.?
- 175 MX WILL NOT KICKSTART
DT175MX Oil Change
The engine oil in this old bike looks a bit gummy.! I don.t think it has been running for a few years (took me weeks to get it running again) What oil should I be putting in it and is there a flush I can get like you can with car engines or will one of those work just as well.? Cheers. Tom PS. I am a printer by trade and can produce repro decals for these old bikes. I have made quite a few for local bikers. Anyone want any.. get in touch [email protected]
New Plug and loads of resistance when Kicked..?
Recently got my 175MX (Off Road - NO ELECTRICS) to run with a hefty Bump Start, when running seems OK, But will not kick start.? Plenty of resistance from the arm, make usual noises but wont fire up. is there I can do to get more Umph.? Thanks. Tom.
DT125R wont run
OK.. Thanks very much for your help so far.. I will get an engine number and take some more detailed pics. thanx again Tom.
DT125R wont run
Yeah.. Bit of a wreck Eh.? But worth getting going... Any th'wiser. I bought new plug and coil but for a DT 125 would this make any diff.?
DT125R wont run
Cant seem to do it that way..? [email protected] post here & I can reply direct..?
DT125R wont run
My bike seems to be the same model as yours (on your reply page) but smaller engine I can send pics if you like..?
DT125R wont run
Erk..! Whats the CDI Unit. there are no markings so I dont know what model it is, thus manual.?? I can send a pic if helps..
DT125R wont run
- DT125R wont run
Tried all of those... for some reason the fuel is just not firing: there is a cut off switch on the bars but I dont know how this should be wired & wires leading to crank case are these important.. apart from this there is very little to go wrong with it.?- DT125R wont run
I bought an old (1982/3) Yamaha DT125R at an auction sale as a non runner. It is very bare, no lights etc. and only suitable for off roading. It had NO SPARK.! stripped & cleaned electronics (Battery seems defunkt but should not matter) now getting a weak spark but wont fire, drained Tank & Carb and fuel seems to be getting to the head (plug is damp when inspected) Could it be a timing problem or mixture.? Getting frustrated cos these machines seem V. simple to operate.!!! Been trying again this afternoon when the plug is out & earthed there is intermintent spark, but put plug back in cylinder bump start.. nothin' could it be shorting out or something.? PLEASE HELP.! - DT125R wont run
