TTR600
  1. Hello all. Has anyone attempted/completed this conversion and if so what lighting coil did they use? I have done this conversion on my 86 TT350 using the XT350 lighting coils and regulator/rectifier this was an easy conversion as i used parts from the road variant. The DT on the other hand is the road version. I have tried the L31 lighting coil for motocross bikes but this is only single wire so i lost the green/white wire which then changes to the white that goes to the rectifier, Since removing this wire i have no neutral light and no oil light on the revcounter. I would like to know if there is another lighting coil that would fit this that has the two wires and is 12volt. Or if anyone knows how to wire in a single wire coil.
