woode1975
Everything posted by woode1975
  1. Hi m8 the problem is a faulty gearbox .I am just debatingg wether to strip and rebuild or to source another engine
  2. I took the clutch apart last night before work and will check it later when I get up thanks m8 Ouch hard luck m8 hope all is well now. Thanks for the input
  3. will do thanks again
  4. just outside Alfreton in derbyshire thanks m8 I am resonably sure it is gearbox related but do not want to strip everything down to find it was something silly
  5. thank you for your time and input
  6. not when ticking over as soon as the drive is under pressure most noticable 2000 rpm upwards till wind noise gets the beter of you as soon as you shut of the throttle the knock will go untill you re-applie thank you hope this hellps
  7. Hellp please I have a FZR 1000 exup 1989 23k miles that has developed a rotational knocking noise which becomes apparent only under accelleration The knock becomes quicker and slightley louder with the engine speed as aposed to the road wheel speed and sounds to be cumming from the gearbox The knock can allso be felt through the bike Would anyone have any idears or suggestions Thanx for your time and input
