Semo18
Everything posted by Semo18
  1. i have to buy a new speedo sensor for my yamaha tzr50, but is there a way i can get one without using yamaha as it is expensive, also ebay i a no go as there is none cheers
  2. yeh i have the same problem in mine it is actually one of the two metal bits inside the senor at the wheel tht has snapped, to check yours you have to take the wheel off.
  3. hi, im having a problem getting my yamaha tzr 50 running it sits and idles for around 1 and a half minutes then will suddenly loose power also if i exceede over 3000-4000 revs it will also loose power i have checked all the fuel pipes and the carb,air filter been cleaned, soon i will drain the tank and try completely new fuel, does anyone have anyother queries to wat might be wrong and how to fix this problem?? cheers, Tom
