Andy1980
Everything posted by Andy1980
  1. where did you get if from? Cheers
  2. Hi I had small arrow indicators in before (none LED) I have taken the back ones off and the standard back set and replaced them with a LED rear set, with built in indicators. The rear set has been fully tested and is ok, it works fine on the bike but when you indicate left both front and back indicators flash quicker then they did with the old light in, it also dose the same for right turns, even the green light in the dials flashes faster. I have been looking on other sites and seen a "wide load flasher relay" needs to be used for LED lights?? Would this slow them down??
  3. i should add my tail light has bilt in indicators
  4. no not yet still trying to get some flush ones to fit my year.
  5. Hi Can anyone help me! I have just fitted a clear LED tail light to my 2000 YZF R6 and all my indicators now flash too fast, is it the flasher relay? If it is what one do I replace it with? Cheers Andy
  6. YAaaaaa that is very useful thanks will have a go tommorrow. hope that is what it is. cheers Bleed the float balls and reset the throttle position and it is running a dream. HAPPY DAY'S
  7. is that how you drain them just with the plugs. did not want to play to much, not to srue what i am fiddling with. What is the best way to get into access it? should i remove all the plastics? all help is good help.
  8. i think i have water in my carb float bowls how would i go about draning these. thanks I check the fuel filter and pipe work, all fine.
  9. alredy checked the carbs and there not sticking what else could be wrong with them? do you think bleeding them would help?
  10. Can anyone please shed some light on this! I just got my first R6, it is a 2000 bike with only 7500 miles on it. The bike cuts out when kicking down gears and stopping, the revs drop and it stalls, checked the norm things like plugs and filters, both fine. The pick up on the throttle is spot on and it runs lovely when ticking over in stand, ride it down the street and stop at the end the revs will dip and the bike will cut out. It starts no problem and your ok till the next time you have to slow rite down. Any help would be great.
