jpdean00
Everything posted by jpdean00
  1. My xj 600 has an annoying knocking noise at tick over, once you open the throttle it goes. After some investigation, it seems to be the starter chain, or drive. Any gems of advise on how to get in their?
  2. jpdean00 replied to jpdean00's topic in Yamaha Workshop
    thanks, I will test the switch. looks like someone has had a go at the electrics in the past, so I may bypass the loom in case the circuit is broken. Any ideas where to get a wiring diagram for the starter assembly?
  3. jpdean00 replied to jpdean00's topic in Yamaha Workshop
    Hi thanks for your help, Neutral light is on, stand up, and clutch in. so I will check the kill switch. When I put power to the starter it only turns, doesn't start, and doesn't appear to spark.
  4. jpdean00 posted a topic in Yamaha Workshop
    I've just bought a non running, 94 diversion from the back of some blokes shed, and it wont start. I have fitted a new coil, battery, and found the starter switch wire was corroded, so have replaced it. When I press the start button, no click, just the oil light comes on. When I bridge the solenoid, it does turn over. What should I check next? Can I test the relays?
