Everything posted by drewpy
SR 125 Custom rebuild
£80? I can get frame and swing arm sandblasted and powder coated for that
quote issue
its the status quote that we need
2 stroke sounds
quote issue
confused dot com first you said then you said do you want to quote or not?
New to Yamaha R6
New to Yamaha R6
Howdy doody
before checking for any offset of the spokes?
Three white wires
you also need to get an inline fuel filter fitted as you'll be pulling rusty bits through to the carb
New member
can you post your bike in projects and not clog up the new members section? will make it easier to find later on
Presentation
Bienvenue Pierre
New member
Honda CB550 Cosworth
can you get him to send some photos? a few peeps are interested at the VJMC page
Sr125 replacement choke pin
#20? https://www.fowlersparts.co.uk/parts/4137320/sr125-3mw5-1996-999-b/carburetor
Gulp!
to the yoc Maulky good intro
I've put the question on VJMC facebook page, so far a blank
xs 250 coils
1/ shouldn't do so long as they coils are the same 2/ compromise between cheap and nasty and cheap but good,
Three white wires
chuck some fuel in the spark holes and see if it fires
cosworth worked for Norton, so they are pretty clued up on bikes.
Newbie
good morning one and all
Jonny, ignore any one dissing your bike, if you like it , that's all that matters
Three white wires
no idea what the ohms figure to the pickup is there's a few different ones out there. You need to check the manual. I had no spark issues few years ago and it was down to a wire, only found by eliminating it by going through back to basics. very fustrating and took a few months to suss. It even passed the OHMS test
Three white wires
stator looks good. those shitty car connectors are realy crap, guess what? they are for cars not motor bikes. I suspect water got in and eroded the wiring creating a resistance, so they heat up. use 3.5mm japanese motorcycle connectors, ebay has them withthe correct shields. you'll also need a different crimper to the car one.
Newbie
well done guy's on the same wavelength
- Newbie
