drewpy
  • Posts
    15,173
  • Days Won
    295
Everything posted by drewpy
  1. depends how long they want the bike from you and if it is damaged, who pays for it? Also will the engine be underwritten for damage testing a non standard exhaust (and your warranty will be void forever) just my 2p's worth
  2. what's the first 3 digits on the engine number? I must admit i've never heard of an RK suffix. This is all i got http://www.vjmw.org/yam_id.htm
  3. also Motolink,motoward, speed sport in america. all online
  4. yep, its got loads more info than clymer and haynes (that's why I bought one, and got it from the states) Is it worth it? it was for me and depends on how much your salary is! there may be better examples out there (mine was new for instance)
  5. this is the one i got http://cgi.ebay.com/ebaymotors/FACTORY-SUP...1QQcmdZViewItem. on ebay now. bit grubby but saves you trying to keep it clean
  6. Ebay, I got haynes. clymer and the official yamaha (the best)
  7. If your putting oil down the bores and spinning it over, watch for oil spraying out. It's just put a couple of squirts in, kick it over on the kickstart and leave to seep into the piston rings in case they are gummed up. Then i'd start trying to start it after a couple of hours. Your igintion timing might be electronic judging by the year, so it shouldn't be an issue unless its been tampered with or the cdi has gone AWOL.
  8. Hi, and welcome. The SOHC xs400(and xs250) models have their camshafts run in the alloy head. These need fresh 20/50 oil. You will need a new (Yam) oil filter to go with the oil. Rubber perishes with age so you need new tyres and tubes you can't use a car battery and ride it, a new battery is only £20 ($$?) clean the air filters of spiders and dust, with compressed air check timing Clean out carbs lube cables spin up the engine with the spark plugs out to get the oil circulating first (And you can check for sparks at same time) any probs post in the classic or workshop section Drewpy
  9. drewpy
    Xs400
    cheers guys, did any of you go to Stafford on Saturday? I did see a blue ac-rd go by on the A34 towards manchester! anyones here?
  10. drewpy
    Leaded/un?
    yep mine runs fine on unleaded
  11. I wouldn't trust it to glue. can you not get it tig welded till then?
  12. there's a bike breakers in farnworth, can you not get one from there? The Bikers Warehouse Ground Floor; Grecian Mill, Worsley Rd North Farnworth, Manchester, Lancashire, M28 5QW Tel: 01204 862832
  13. I get the workbench out, and a petrol can. Stick a length of pipe in the petrol and suck. When the fuel comes out stick it on the carb fuel inlet. voilla!! fuel ps everthing tastes like petrol for a day, but with the wifes cooking, that's a bonus
  14. Wow lots of questions and where to start; 1) pilot screws on mine are 1 turn out from fully screwed in +/- 1/4. don't over tighten or they might snap off the fine needle in the carbs 2) I got a spare 250 carb for spares if your desperate 3) I got a set of 4 indicators from Stafford for £20 and they look the biz, you can get studing from B&Q and cut to fit! 4) carbs need balancing 4) Try granby motors, Motoward and Motolink for yam spares 5) You need to thoroughly clean carbs of all gunk, in the end, i had to send mine off th JRS to be ultrasonic cleaned 6) You don't need to remove air filer to access any adjustments, they will be accessable from above (take off the tank) never run the bike without the air filters Any more probs just let us know! Drewpy
  15. drewpy
    Xs400
    Hi, Just finished restoring my xs, and thought I'd share it with you. Mods have included twin disk with xs1100 master cyl and drilled disks all round. Just been out to Rivington today on it and it ran beautifully, can't wait till Stafford
  16. cheers, I tried Peeks polish with no luck. I'll try solvol
  17. Hey, Iv'e restored my xs400 for the summer and gave it its inaugral run yesterday. Thing is the headers have become discoloured and i was wondering does anyone have any tips on cleaning this up? I am useing the Motad system t the mo' and they use stainless steel pipes! I know about "Blue away" product, but is there anything else? ie cheaper Cheers Drewpy
  18. use copper grease on the threads next time
  19. You are best to get yourself a haynes manual for starters, that way, you will gain basic knowledge for your bike. try http://www.yamaha-xt500.co.uk/portal.php its mainly xt but the sr has the same engine as the xt. your seat should open by key, and them you will see the hinges. with the seat up you will be able to see a bolt or bolts to hold the rear of the tank on, then wiggle backwards off the rubber. you can see an sr parts catalogue here. try 1980 theres's an sr250 listed there http://www.starmotorcycles.com/star/parts/home.aspx
  20. I assume you mean spark plug leads and not spark plugs You can always unscrew the plug caps and get some shrink tubing from electronics store (Maplin out there?) then shrink it on the leads with a heat gun. As regards the kick-start, iv'e seen the gear mesh inside the casings sheared off before now, so it could mean an engine strip. Just bump start it, you sound like a big boy If your really keen, take off the right casing cover a check the kickstart shaft as it enters into the gearbox, you should be able to see it to confirm condition. as to the noises on your bike, I assume you have changed the oil and filter within the last 1000 miles?
  21. Damp in the ignition, drained battery, water in the tank if cap was off! take out the spark plugs can you smell petrol? connect up your spark plugs and earth to cyl head, do you get a spark? Charge up the battery drain tank and put fresh petrol in.
  22. you might not be able to replace the leads, because they can be glued into the coil, depends on the model. As for tank, one bolt at the back and "wiggle" the tank towards the back, lifting the rear of tank by couple inches. watch out as it will let go very quickly (held on with rubber "bungs" into frame) it will be easier to do the valves with the tank off. PS don't forget to undo the vacum and petrol pipe from the tank first.
  23. inlet 00.8 - 0.12 mm exhaust 0.16 - 0.20 mm drew
  24. try this link http://www.starmotorcycles.com/star/parts/home.aspx usa but you can see the parts you need. Iv'e used standard generic and stainless bolts on my restoration. try B&Q
  25. If you can get a larger nut over the bolt head, you can then weld it on inside the allen bolt (build up the weld to inside the nut). due to the different heat characteriscts of the metal, it will break any alloy corrsion. Then you can get a socket over the nut and turn. his also works on studs snapped off flush with alloy heads. You could also get a dremel and cut a groove, then use an impact screwdriver. BTW any bolts that are tight should use heat if possible and an impact driver. Drew
