Everything posted by drewpy
Melted Regulator plug
http://www.vehicle-wiring-products.eu/VWP-...iconnectors.php http://www.autoelectricsupplies.co.uk/category/1
Yamaha XS250 identification
1M0 is xs250c never heard of N88 but could be aussie region specific Drewpy
400special main fuse popping
I'd disconnect each electrical item first then reconnect bit by bit and see if it blows. when it does, that is your problem
1976 xs 360d
It would help to say that you've tried all the usual options, then we don't have to make assumptions. they are the same carb type ie mikuni 34 mm so should fit yours. For a few dollars its worth a go.
1976 xs 360d
there's a company on ebay that sells carb kits and they are based in Canada. first do a search as I have posted web based suppliers before and can't be arsed typing them out again!!
Engine rattle
you need to get a manual. It will pay for itself in no time
Engine rattle
sounds like pre-ignition. have you checked your ignition timings?
master cylinder problem
spped and sport has one Part Number Description Model Prefix On Hand Price Add Cart 1 1J7-25850-52-00 MSTR CYLINDER ASY XS750 D 1J7 1 $198.72 check part number against you parts list first
Yamaha XS850 Midnight Special
have you tried www.cmsnl.com based in holland www.motogrid.com american www.yamahatopdog.com american www.bikebandit .com american www.nwvintagecycleparts.com/ Its really no big deal getting stuff from usa especially when the pound is so strong at the moment. I've had to use these guy's for my xs400 resto.
great fork seal removal tip
good to hear you got it sorted, jobs like that drive me mad with fustration!!
- xs360
- xs360
FOOTPEGS 82 XS400
the rubbers should be a tight fit on the shafts and secured by bolts. motogrid do them.
Surging TX650
I'd get it on a rolling road dyno and get a fueling curve printed off. It will tell you what you need to do and save loads of time.
removing fork oil seals
another tip i've remembered, use a plastic waste pipe to hammer home the seal.
I haven't got a YB but check for a allen bolt at the bottom of the sliders. you need to break them fast or they'll turn and then you have to make a tool to hold a nut the other side ( a very long tool).
I use a tyre lever and rag to stop any indents in the alloy and a LITTLE heat to soften the rubber. If its really low drill a hole and screw in a self tapper for some thing to pull up on. I'm assuming you have taken off the stantions.
oil and running problems
YPVS is solinoid operated via electronics and is used to enhance low rpm ie shortens the exhaust length. It can stick but the whirring you hear is the checking system.
xs400 backfire and crappy revving
you're correct in assuming the pipe seals are to blame as that will produce the backfiring you are experiencing. You should have a gasket there, but it may be compressed and does look at first to be part of the cylinder head. try cleaning around the exaust port and check for a gasket (they can be metal copper or steel concertina shape) hope that helps, if you seal the exhaust and it still backfires, then timing or fuel mix is to blame.
1978 xs400
erm..no thimble full at most there's no seal there, maybe try tightening the case bolts. 8mm = 2.0 - 2.4 lb ft 6mm = 0.8 - 1.2 lb ft ps I am talking about the left side of the bike (as you sit on it) as the engine only takes 2 litres (2.3 with new oil filter) so hopefully your not removing the clutch side?
Astley Green Colliery, classic bike gathering 1st July
this a great gathering organised by the LE velo club. Its situated off the east Lancs road. Lots of different bikes attend and there is a great (free)museum housing one of the largest steam engine winders in the UK. 11am to 4pm directions here
1978 xs400
LT is left timing for the valves on that side RT is the right timing for the valves on the right make sure the piston is at TDC by removing the sparkies and feeling compression with your thumb. inlet (carb side) is 0.08 - 0.12 mm exhaust 0.16 - 0.20mm A little oil does come out and my engine has only 2k since rebuild
- XS400GS
RD250E/DT250MX RESTORATIONS
you obviously got too much time on your hands. Very nice bikes, hats off to you!!
XS400 REAR WHEEL MAX TYRE SIZE
great, that wheel is off a custom model
