Everything posted by drewpy
1980 Yamaha XS400SG ?'s
Yamaha cup xs400 with Kenny
front fork seal replacement and questions
1) If you have screw caps or a circlips for the top of the stantions to hold in the springs, take these off first as its easier to do when on the bike. take off front wheel, loosen the pinch bolts and the stantions should just twist down. I would suggest raising the bike further off the ground to prevent them bottoming out on the ground. 2) to take off the stantions from the sliders, there usually is a capscrew socket underneatth. If you don't "snap" it on first attempt, the insides just start turning and you need to make up a lonnnnggg tool out of tubing. I also put the spring back in and with my back to the wall, pushed the spring in via slider, and turned the capscrew off that way. clean everything out and heat up the old seal and prise out with a tyre lever (taking off clip first). to knock back in, use a plastic water pipe of the right diameter for the seal (ie outer, not soft inner) 3) No idea!!! Drewpy
Brand new DT175...headlamp dims profusely when brake light and/or indicators are used.
Hi, Have a look here as I'm sure there will be something for you!1
there's not a lot really, Motad exhausts, and the cams mentioned previously. you can go twin disk up front using SR 500 left fork and caliper with an xs1100 master cylinder. the yam xs's were pretty much perfect as they came. there was even a Yamaha sponsered race in Germany called the Yamaha Cup and these used XS400's for a time. These came with full fairing and plastic combined tank/seat unit. everthing else was standard.
who rubbers you prefer?
Durex, machine= mens toilets in red lion
81 xs400 high idle after deceleration
pilot system too lean. do a search on forum, talked about plenty of times
78/79 xs400 Head light
not really, the wire from the switch was already there, being part of the left switch loom. I just had to buy some japanese type bullets and solder tup o the ignition switch by copying the old one I had.
I'm using 10w 40. I did use 20w50 and if you have really hot weather then i would go for that. I use semi-synthetic as full synth with make your clutch slip!! the best tyres i have in use are Bridgestone BT45, the RD boys recommend these as well As far as tuning goes Megacycle cams do a reprofiled cam for the xs click here for specs etc try bike bandit as they will list your bike and also publish data. Drewpy
Hello from the newbie
Wecome! Keep your eye on the garage as mods go in there Drewpy
xs 360 runs on right cylinder only
# check your valves as they could be leaking/mal adjusted pilot screws as a keyster kit from sirrius online in canada or I got a set from motoward yamaha dealer (just google)
gas tank sealer and petcock gaskets
try here
Engine dies when choke is closed
I use the smallest i could find with a see thru bit so I know I can check for fuel (if the bike starts mis behaving) on the move.
xs 400se
re-check your clutch actuating mechanism has been installed the right way round and is fed correctly with the screw part. Also check the "fingers" of the clutch basket that they are not ridged as this will prevent the plates separating. you can dress them a bit but not too much or the plates will start chattering.
gasket from here POR 15 is the stuff you want for sealing, check the prices and compare with the quote.
xs 400se
the springs should measure 34.6mm free length. if they measure 1mm less than this, then they should be replaced. Is the mushroom head on the end of the rod? check for warped plates using a sheet of glass
yep they control idle to 4 - 41/2 K revs. my bike used to rev on idle which means too lean. just richen up on the pilot screw.(after you have unblocked it)
78 xs400 carb help
just get them ultrasonically cleaned, you can buy cheap ones, but big enough for your carb and they also clean your dentures!!!
xs 400se
I suspect the ball bearing at the end of the pushrod is missing
UK bikes don't have relays. the 4th wire feeds the main beam pass switch. I had to solder an extra wire from the ignition switch live to the pass switch on the left side and back to the headlamp main beam.
its your pilot jet, this is the smallest drillings in the carbs and will clog up first. You also need to fit a fuel filter as your tank will have rust particles from gas stations and in the tank itself. Try some of the proprietry carb cleaner you put in the tank and see if it unblocks. You could also open the screw another 1/2 turn and see what happens. mine always runs the roughest at 4k revs. this is the point where the main jet starts to take over from the pilot system. Just age and 30 year old technology really.
78 xs400 carb help
If youv'e had the bike from brand new and you can say you have never had a screw driver on the pilot, you can eliminate that then. if you have the carbs off, take out the pilot screw and feel under neath for a little "pin" if its there its snapped off!! Its an air screw, in for rich out for lean.
78 xs400 carb help
A common problem was hamfisted peeps overtightening the mixture screw in, then the fine brass tip snaps off in the carb body prventing any change in the low speed mixture. my carb had both of these and got an engineering friend to "push" them through. It opened up the hole slightly but I just screw in the new screw more.
Yamaha XS250
all the points do, is pass 12v to the coils for the appropriate amount of time (dwell). I did say do your timing first, assumming that the points gap was already initially set (which they are) then reset them after the timing
XS400 Repair Manual
I would try it as you will get better acceleration. I had a similar setup and i was great. fuel consumption was worse and you tended to race other bikes/cars up to 80mph, so engine life would be shorter. I now run 1 tooth over just to tame my red mist
Yamaha XS250
do the timing first, then reset your points. invest in a Xenon strobe £20 off ebay.
