.jpg.5c05eb7af257e741ca000bd984024429.jpg)
Everything posted by drewpy
1982 xs400 main fuse blowing
I think its a case of disconnecting electrical connections, then starting with the ignition switch, turn the key, connect something else, turn the key etc. i would start with the starter motor + solinoid first.
Powder Coat
mods should post a "sticky" £30 seems steep when you can get a frame and swing arm powder coated in black for £55 at triple S (inc masking and blasting)
80 XS400 Battery
seen some on german ebay, try there!!
Paint color for my XS400
not sure about copper. look at this...
XS400 Tank Swap?
1st 3 numbers on your engine # will do
XS400 Tank Swap?
we need to know what year and model the xs400 is, there are at least 4 variants over the years!!
81 400 special running lights and throttle issues
you have to strip the carbs down. you can do all the jets ans the carbs would have to be turned over. larger more expensive ones you can immerse the whole carb in it
- Clutch problem XS360
81 XS400 - How to Remove Starter
sorry mate, should have been more explicit. Mikes xs is a shop http://www.mikesxs.net/mikesxs-tools.php?category_id=7.1 Alternator Rotor Puller - Safely pulls rotor without damaging it. Fits: All 650’s. Part #35-0040 $10.00 USD EA. I think nthat this will do it, need to check thread size with yours
European commision.....
Aktung snell snell!!!
Add an oil cooler to a SR250?
the xs750/850's have theirs twixt crankcase and oil filter housing. ie from the oil pump, round the cooler and into the filter.
Engine stays at high rpm
and a different flasher relay http://www.norbsa02.freeuk.com/goffybulbs.htm do hals for older bike fitment. he attends stafford shows in uk as well.
yeah like that opera bird on luc besson's 5th element film!
only cos its cheap. used it the other day and it works a treat, used warm water and a surficant cleaner (w/up liquid type stuff but no salt) more expensive ones have a heater and larger capacity for speed, i just turn the part around just takes longer.
Finding Parts
bikebandit motogrid yamaha top dog
anyone know a good vintage kawasaki forum?
AAARRR he's gone kwakers!!!
its a sure fire method of cleaning your carbs using ultrasonic sound waves
just get a socket and undo the bugger. it may be tight if its not been touched for a while as the unit sits in line of the front sprocket. if you are really pernikity, take off the whole sprocket cover, unhook the clutch cable and undo the worm unit from inside. put in a vice and go at it from there!!
ultrasonics the way, I'll tell yer!!
crud/swarf making a connection. undo the left sprocket cover and there should be an iory colored plastic thing with 3 countershrunk screws and 1 connection. take this off and clean it. BTW
1978 Yamaha XS400 - Cleaned Carbs
its an air leak or too much air getting into the mix. mixture screw should be 2.5 turns anti-clock wise from bottoming out. check intake rubber for cracking
its the starter clutch, there are little cylindrical "bearings" which are pushed aginst the crank by little springs and when the engine is stationary the starter motor can spin the clutch up and the "bearings" grip the crank and turn over the engine. when these wear flat they just spin round the crank. to repair you need to take off the left covers and pull off the stator to get to the clutch. special puller is needed to extract the stator. and you can buy clutch starter kits from mike xs which i think fit yours drewpy
XS360 No spark?
thats a lot of oil to burn. yes you do need a battery power to start. its not a magneto bike. check your contacts for pitting and check for flashes from them when a friend kicks it over! (condensors knackered) most prob your carbs have varnished if left with fuel in over a period of time, have you tried easy start?
Dr. Dave
good one. btw; for the americans here, its not a vietnam vet we a talking about !!
National Eczema Association
The National Eczema Association are currently fundraising. They've just launched a scratch card.
