drewpy
Everything posted by drewpy
  1. drewpy replied to mervin's topic in Yamabyss
    the only bush i like is on the wife's...aherm!!
  2. drewpy replied to mervin's topic in Yamabyss
    Texan....bite through the chocolate and chew.....reeal sloww...
  3. don't think, just do it. you should be able to do at least 100miles. I used to do a lot of cycling and 90 miles all day was easy circa 15 mph (inc pub stops) the pictures you'll take and the laughs you will have will live with you for the rest of your life. Why not try youth hostels?
  4. got it off CMM
  5. should be wearing gauntlets
  6. its a standard service item, strip the back wheel and regrease like old git says and i would also grease the pedal pivot
  7. drewpy replied to mervin's topic in Yamabyss
    O loiks the bats.
  8. drewpy replied to mervin's topic in Yamabyss
    BIN DUn 4 posts down
  9. must be xj
  10. he's right. If the pilot mix is near the engine in front of the body its a fuel meter, so opeming the jet richen's the mix. if its located between carb body and air cleaner its an air meter and opening weakens the mix as it lets more air in!!!
  11. or vaseline
  12. drewpy replied to G-man's topic in Classics
    http://www.siriusconinc.com/default.asp
  13. few pointers... check the tyre is not rubbing on the swing arrm is the hub hot? My mates 125 did this and the previous owner "forgot" to replace a spacer hence the bearing totally collapsed. chain oiled? brake free play correct?
  14. drewpy replied to G-man's topic in Classics
    try speed & sport, they seem to have amassed lots a yam spares BTW they aren't part numbers, they are specs from mikuni via haynes manual.
  15. 4k is when the mains start to kick in so I would check diaphram for tears and smooth lift. check spray bars in carb.
  16. I've suspected for some time now that my wife has been cheating on me. The usual signs... Phone rings but if I answer, the caller hangs up. My wife has been going out with the girls a lot recently although when I ask their names she always says, "Just some friends from work, you don't know them." I always stay awake to look out for her taxi coming home, but she always walks down the drive. Although I can hear a car driving off, as if she has gotten out of the car round the corner. Why? Maybe she wasn't in a taxi? I once picked her cell phone up just to see what time it was and she went berserk and screamed that I should never touch her phone again and why was I checking up on her. Anyway, I have never approached the subject with my wife I think deep down I just didn't want to know the truth, but last night she went out again and I decided to really check on her. I decided I was going to park my motorcycle next to the garage and then hide behind it so I could get a good view of the whole street when she came home. It was at that moment, crouching behind my bike , that I noticed that the valve covers on my engine seemed to be leaking a little oil. Is this something I can fix myself or should I take it back to the dealer?
  17. drewpy posted a topic in Yamabyss
    A motorcycle cop comes across two bikers. One biker has two fingers up the ass of the other. " What the hell are you doing?" asks the cop " My buddy here's got some food stuck and is choking," says the one biker, "I'm trying to make him sick." "You're meant to stick your fingers down his throat, not up his ass," replies the cop. The first biker says, "Yeah, I know, but you get better results if you stick them up his ass first..."
  18. drewpy replied to G-man's topic in Classics
    the 400's use the same carb, but have different jetting and needles
  19. drewpy replied to R6_Martin's topic in The Bar
    great vid, watched it to the end whats the music track?
  20. drewpy replied to G-man's topic in Classics
    main 135 air jet 0.6 jet needle 4fp21-3 needle jet X-6 pilot 17.5 starter jet 40 I guess you contact mikuni for parts
  21. arc weld a nut on it, which will do 2 things, 1) heat up the steel/alloy area 2) use a larger socket to provide more grip drewps
  22. drewpy replied to auldyin's topic in Yamaha Workshop
    calipers are the same as xs400's (sohc) and sr500's if i'm not mistaken!!
  23. go to your boneyard and get another one, might be the easiest way!!
  24. faulty starter soleniod?
  25. just done a cg125 carb, stripped and cleaned in the ultrasonic bath (from Aldi) and put together in 1 hour. doddle doodles main jet was clogged and accelerator valve stuck shut!!
